DC4LSTEGs HUGE MOVING SALE!!SOMETHING FOR EVERYONE!!LOTS OF PARTS!
Im not on here much please text me. Im located in Oak Hills 92344 might be able to meet around Azusa or Anaheim during the weekdays 9-5. Will ship.
TEXT-7604750387
EMAIL-DC4LSTEG@GMAIL.COM
NO TRADES!!
PLEASE BUMP IF VIEWED!!
-Garrett GT3540B "Wolverine." Purchased from "The Shodan"(STC). High heat black coating on both covers. BNIB!!
$900
SPECS:
Compressor:
T04B - extrude honed compressor cover
61lbs/min GT35R OEM cast wheel
Cartridge:
1/8thNPT feed fitting thread pitch
3/8NPT water fittings,
standard 1/2" return flange
Turbine:
T31 4 bolt 2.5" .63A/R housing
71mm Garrett exhaust wheel
Heres the link to the video description,
[/URL]
-CTR 32mm 5 lug conveersion. Arp extended studs and SS brake lines all the way around etc. $1000
- Ctr rims almost completely stripped one has bend still works fine, comes with caps- $325
-OEM CTR power door panels mint- $350
- OEM CTR power folding mirrors in FBP- $250
- Recaro seat covers in black $60
-B18C5 Bare Block w/ vin. Comes with main caps that have new bolts. Block webbing cut on front, freshly bored 81.5mm and resurfaced. $475
-OEM CTR Wing- was CW, rattle canned black-$275 no adjustable brackets
-Buddy Club Spec 2 Exhaust w/ silencer for 96-00 civic hatchback- has some scratches could use a good polishing- $300
- OEM CTR 96-98 Front lip- has some cracks/rips still mounted fine, rattle canned black- $150
-Tein SS w/ upper spherical bearing top hats for EK. Rear are still on car. $800
-96-98 Civic VIS cf hood- still has a shinny clear coat small damage on back corner pictured- $300
-Red Recaros seat rails passenger(jdm) has Bride Low rail driverside is oem- $800
-OEM CTR red carpet- has a little wear, previous owner made cuts for lhd car(couldnt see them with kick panels in place)- $225
-OEM CTR 96-98 Gunmetal housing headlights- Could use a good polishing has broken tab pictured- $225
-Sparks B Series mini ram and 5 bolt downpipe. Manifold has been braced in the back, downpipe slightly dented. $250
-Turbosmart 38mm wastegate w/ springs.. $125.
-B&R Turbo coolant lines in black- $100
-Cxracing 96-00 civic b series intercooler piping- has 1/8npt bung jb welded 6" before tb in the back of the pipe and intercooler. $100 will seperate
-OEM ITR Gold Shift Linkage- $100
-ITR Oil Cooler. $60
-2 VTEC solenoids one has cut top wire. $40 for uncut and $20 for cut one
-2000 LS B18b head. no cams, intake mani, or dizzy. $80
-Milspec plug with pins. $100
-Blox Gold ball shift ****. $25
-5 bolt downpipe flange. $10
-Block catch can adapters..$30
-OBD2A oem altenator..$50
-OBD2 LS Dizzy TD-84u.. $60
-LS Flywheel. $30
-CRX SI rims. 2 wheels almost brand new, 2 could use replacing but hold air. $175.
-Black EG manual door panels in pretty good condition. $60
-EG climate control..$25
-DC Black dash..$40
-OEM ITR water pump mounted but never used. $40
-H Series manual trans case..$75
-DC integra ls gauge cluster..$30
-96-98 Civic clear HID forglights..$50
-Strut bars $40 each for bottom 2, $15 for the top one
-DC Integra LS stock header. $40
-B Series Tri Y header. May need to be milled on flange..$150
-ARP B18c rod bolts. Torqued once never started. $40
-DC Stock camber arms..$10
-ABS module off my 98 CTR. $20
-B Series axles and half shaft. $80 for axles $60 for half shaft
-2000 Integra ls front and rear sway bars. $30 for front $20 for rear.
-EM1 Si power mirrors. $40
-EG armrest, steering wheel, cluster bezel, ek cupholders, and misc vents..make offer
-OBD1 Virgin P28..$90
-2 Gates B18c timing belts 1 brand new 1 less then 1k miles. $70 for new one, $40 for used.
-2 EG harnesses, not perfect condition. $50 each
-Black EG carpet out of coupe..$60
-OEM GSR Intake Manifold..$30
-OEM CTR Panels. $60
- Also have 2 eg coupes I will be parting out. White one is an EX, red is a DX, both have black interior and are manual. LMK what you need. Still have interior stuff and rear disc brakes almost everything except stuff in the engine bays
TEXT-7604750387
NO TRADES!!
$900
SPECS:
Compressor:
Cartridge:
Turbine:
[/URL]
-LS Flywheel. $30
-DC Black dash..$40
Pending but shoot me a text ill let you know if it doesnt sell
Calls me a liar for not having parts he needs, but texts me about the HIDs
Shoot me a text
Yes I do
Thanks for all the bumps and kind words guys!!
Shoot me a text
Yes I do
