Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
No codes, but still hesitating 95 civic
Old Jun 13, 2013 | 05:14 PM
verynew2honda's Avatar
Icon2 No codes, but still hesitating 95 civic
Hello. as you can tell, I am new to the Honda world.
My daughter presented me with her 95 Civic,with a 1.6 non vtech, after taking it to several shops, and asked me to look at it. She gets a hesitation every couple of days,sometimes the cel light comes on then goes off and no code is stored.
The shops have changed the cat. converter, distributor, as well as brakes, master cyl. and clutch.
When I first looked at it, I found loose spark plug wires, oil in spark tubes and a loose spark plug, as well as a very dirty air filter.
to eliminate normal problems, I changed the valve cover gasket and tube seals, new plugs, cap, rotor, wires, fuel filter, pcv, and air filter, as well as an oil change.
It runs much better(go figure) but still has this intermittent problem.
I hate to be a parts changer, so if anyone could help, I would appreciated it very much.
verynew2honda
Old Jun 13, 2013 | 05:42 PM
m_shake's Avatar
Default Re: No codes, but still hesitating 95 civic
Yeah, this is the 2006 and newer section...maybe something to do with map or tps sensor. Good luck.
Old Jun 14, 2013 | 04:30 PM
My bad, sorry and thanks
verynew2honda
14
Jul 1, 2013 02:19 PM
Bruce_Leroy__
Oct 16, 2011 10:53 PM
BRealtoYourself
Nov 6, 2007 03:08 PM
joaodossantos
Jun 9, 2007 08:18 PM
TimsTeg
Apr 24, 2003 04:32 PM
