How to remove '1' cylinder Head bolt head by drilling?
Old Jun 13, 2013 | 03:08 PM
faran's Avatar
Default How to remove '1' cylinder Head bolt head by drilling?
Hi Guys-
So I am trying to do a Headgasket on my 1994 Accord EX F22B1 because of overheating issues.
Long story short, I am unable to pull the head and do Headgasket because of '1' Damn bolt
I am drilling on the bolt right now with a Milwaukee drill bit and used engine motor oil as a cutting oil.
I am kind stuck now, not sure how to completely remove the head of the bolt, so I can pull the head?
Please have a look on the pictures and advice, I am kinda stump now. Because if I try to drill by using 9/16', it's not removing anything and seem like bolt head is not budging
Thanks in advance for all of your help and advice.
Old Jun 14, 2013 | 05:14 AM
kyden's Avatar
Default Re: How to remove '1' cylinder Head bolt head by drilling?
have you tried using a bolt out socket?
Old Jun 14, 2013 | 05:54 AM
faran's Avatar
You mean at this point or previously? Before I started drilling, I have tried various bolt extractors, but no luck
Since the space is too tight, I can't even use a cutter or grinder.
Any other suggestion for removing head of the bolt?
Old Jun 14, 2013 | 06:17 AM
Black R's Avatar
25 Year Member
Go to sears and buy the reverse threaded bolt extractors and reverse drill bit extractors.
You don't need to cut the head off the bolt - just get a grip on it so you can remove it.
Old Jun 14, 2013 | 06:43 AM
faran's Avatar
Please don't take me wrong but these BOLTS need a lot of torque to crack them open, I had to use a 4" long cheater pipe with 1/2" breaker bar to break loose 9/10.
Do you think those extractors or reverse drill bits can crack them?
Please advise and a picture would be great if you can possibly provide?
Old Jun 14, 2013 | 06:53 AM
myEKsedan's Avatar
dont worry about an extractor at this point. drill out the bolt untill the head of the bolt pops off. removed the head, and try to unscrew it the rest of the way with a pair of vice grips. also, you may be able to use a step drill bit but be careful not to cut into the head.
Be sure to give it a thorough cleaning and remove all the metal shavings before reassembly.
-Chris
Old Jun 14, 2013 | 07:02 AM
faran's Avatar
-Chris
Thanks brother, do you think removing just the remaining portion of the bolt from the head will not be a PITA?
Also, these metal shavings, I am picking them up with a small magnetic tool, anyway they can go into the block and cause any trouble?
faran
Jun 20, 2013 12:36 PM
faran
Welding / Fabrication
21
Jun 18, 2013 06:32 PM
tensaiwung
27
Mar 28, 2012 10:02 AM
bow tie
Nov 15, 2008 05:11 PM
Beau Gotti
Sep 10, 2006 12:25 PM
