NY 2000 Honda Civic Hatchback w/ Turbo GSR Swap
Old Jun 13, 2013 | 02:44 PM
sdobson910's Avatar
Default NY 2000 Honda Civic Hatchback w/ Turbo GSR Swap
EXTERIOR:
Taffeta White (150K on shell)
- Some dings, scratches
- Surface rust was showing on bottom of hatch door, this has been sandeddown and plastic dipped over to prevent more rust
Front fenders have some surface rust from previous owner doing a DIY fenderroll, no rust on rear quarters, overall pretty rust free car, originally fromFL and very clean underneath
OEM 99-00 SI front lip painted FBP with brand new OEM hardware
Spoon replica carbon fiber duckbill spoiler
EBay 99-00 SI grill
Repainted OEM side skirts
MOTOR:
95 JDM GSR Motor (only 4K miles since rebuild, broken in w/ Brad Penn 5w30Break In Oil, currently a fresh oil change w/ Castrol 5w30 Full Synthetic)
Cleaned, Honed and Assembled by BRK Race Engines in Alden NY
Block and Head Painted Gray w/ VHT High Temp Engine Paint
Stock Head w/ New OEM Valve Stem Seals and Relapped Valves (all done by BRK)
New OEM Cam Seal
Stock Cams and Gears
ARP Head Studs w/ OEM GSR Head Gasket
Wiseco Pistons 8:9:1 Compression
Eagle H Beam Rods (ARP rod bolts)
Block Built to Support 500HP
ACL Race Bearings
OEM Thrust Bearings
New OEM Gaskets and Seals
New OEM Timing Belt and Tensioner
New OEM ITR Oil Pump
New Alt and PS Belts
New AutoZone Alternator
Misc OEM Bolts Replaced Throughout
Innovative Motor Mounts Black Anodized
New NGK Blue Spark Plug Wires
NGK Spark Plugs 1 Step Colder
Skunk2 Intake Manifold
Thermal Insulated Intake Manifold Gasket
Skunk2 Alpha Throttle body
Omni Power 2.5bar Map Sensor
OEM Type R Bracket and Throttle Cable
AEM Fuel Rail (Silver) w/ Fuel Pressure Gauge (bought new from Swerve)
RC 550CC Injectors
Black Braided Fuel Line
Broken in w/ Brad Penn Break in Oil 5W30
B16 Valve Cover Painted Wrinkle Black
Blox VTEC Solenoid Cover
Go-Autoworks Aluminum Half Radiator and New Upper and Lower Hoses
Go-Autoworks Slim Fan
TRANSMISSION:
Stock 98 GSR Transmission
New OEM Honda Transmission Fluid Flush 4k Miles ago
One piece -3AN Stainless Steel Braided Teflon Coated Line from the Clutch Master Cylinder to the Slave Cylinder
New Clutch Slave Cylinder
ACT HDSS Street Clutch and HD Pressure Plate
ACT Streetlite Flywheel
New Throw Out and Pilot Bearings
Skunk2 Short Throw Shifter and Type R ****
ES Poly Shifter Bushings Front and Rear
TURBO COMPONENTS/EXHAUST
Spoolin Performance Log Manifold and Dump Tube
57 Trim Turbo (NO SMOKE OR OIL LEAKING)
DEI Turbo Blanket
AEM Dry Flow filter on 2.5in Intake
Custom DP 2.5in to 3in Exhaust built by John Donovan
Stainless Steel Feed and Return Lines from B&R Fittings
2.5in IC Piping
Greddy Type RS BOV
TIAL 38mm Wastegate w/ 8lb Spring
Blox Manual Boost Controller (set to 16psi)
Custom 3in Exhaust Straight Through to HKS Muffler (also have a BNIB 3inVibrant Stealth Muffler)
Blue Blox Vacuum Block
Mishimoto Black Intercooler
BRAKES:
Blank Front Rotors (7-8K miles)
Hawk HPS Front Pads (7-8K miles)
Rear Disc Swap from GSR w/ rebuilt calipers (all new shims and seals, ES trailing arm bushings)
New pads and blank rotors for rear when installed
Russell Stainless Steel Brake Lines (to be installed w/ disc swap)
Brand new OEM 99-00 Civic SI parking brake cable (will be installed withswap)
WHEELS AND SUSPENSION:
15X7 Flat Black Rota Slipstreams
205/55/15 Kumho Ecsta tires (around 9K miles)
Rays Engineering flat black lug nuts, set of 25 with locking key
Tein Super Street Coilovers
Omni Power Front upper adjustable control arms
Ingalls adjustable rear upper control arm
Skunk2 Front strut tower bar
New ball joints
Integra rear sway bar w/ 99-00 SI hardware (brand new OEM hardware) and ES bushings
MISC:
New Fuel Filter
New AutoZone Battery
No A/C but does have Power Steering (still have compressor and some lines for A/C)
ECU and TUNE:
Car was tuned by John Donovan on his dyno w/ Chrome, it’s a OBD1 P75 ECU Chipped for VTEC
The car made 309WHP and 235TQ on 16PSI, I believe around 240-250WHP off the wastegate
We did another street tune last year with the addition of the Skunk2 Throttlebody, and the car runs great
Two Step set to 5500RPMS, Redline at 8400RPM, and Shift Light (check engine light) at 7900RPM
Old Jun 13, 2013 | 07:21 PM
olsonski's Avatar
Default Re: 2000 Honda Civic Hatchback w/ Turbo GSR Swap
Bump. Get the headlights sanded and clear coated dark gray it'll look way better.
Old Jun 14, 2013 | 06:29 AM
sdobson910's Avatar
It was raining in these pics so the weather wasn't really cooperating. They are not that cloudy when dry, but I will be refinishing them either way.
Old Jun 15, 2013 | 09:15 AM
sdobson910's Avatar
Bump
Old Jun 17, 2013 | 01:35 PM
gotboosthatch's Avatar
Trade check thread pm me
Old Jun 19, 2013 | 05:54 AM
sdobson910's Avatar
Bump to the top.
Old Jun 20, 2013 | 07:17 AM
sdobson910's Avatar
New price 7500obo
Old Jun 22, 2013 | 12:03 PM
sdobson910's Avatar
Bump
Old Jun 23, 2013 | 03:15 PM
91lsteg's Avatar
Would rt awd wagon's....2 get ur attention
Old Jun 25, 2013 | 12:04 PM
sdobson910's Avatar
No thanks on the wagons, just looking for an EG Hatch. And also new price 7K obo.
Old Jun 27, 2013 | 05:00 PM
sdobson910's Avatar
6800obo
Old Jul 17, 2013 | 09:00 AM
sdobson910's Avatar
Bump motivated to sell, 6500obo shoot me offers. Need money for a house.
Old Jul 19, 2013 | 10:40 AM
sdobson910's Avatar
Friday bump
Old Aug 8, 2013 | 10:32 AM
GSnotAtypeR's Avatar
you still got it?
Old Aug 8, 2013 | 03:29 PM
sdobson910's Avatar
I do.
Old Aug 9, 2013 | 06:36 AM
EK FLY's Avatar
friend of mine is interested we are down in MD , would u take 5k for it ? text me at 2404808400
Old Aug 9, 2013 | 08:08 AM
subtlecuddle's Avatar
Is there any rust anywhere on the vehicle?
Old Aug 9, 2013 | 09:48 AM
0_o1TiMeXx's Avatar
pm'd
Old Aug 9, 2013 | 10:07 AM
sdobson910's Avatar
Yes in the spots mentioned (rear hatch and some, one spot on pass side rear where paint was scraped off, and the fenders), its all surface rust and the rear quarters are in great shape.
Old Aug 16, 2013 | 08:48 AM
sdobson910's Avatar
Bump still around, can remove parts for lower prices if interested.
Old Aug 23, 2013 | 06:09 AM
sdobson910's Avatar
Bump new pricing options.
Old Aug 23, 2013 | 06:13 AM
psi2high's Avatar
Not bad prices at all. Cant believe no one has jumped on this yet
Old Aug 23, 2013 | 10:10 AM
sdobson910's Avatar
Thanks, yea I don't know I guess cars don't sell anymore. I see poorly built civics sell all the time in my area, and this one I cant do anything with. I have a few offers but not for what I'm asking.
Old Aug 23, 2013 | 08:22 PM
psi2high's Avatar
Yea its tough as Honda prices have pretty much plummeted unfortunately.
Old Aug 26, 2013 | 08:54 AM
sdobson910's Avatar
Bump cause its Monday
