cant full throttle?
Old Jun 12, 2013 | 06:41 PM
Nick Cello's Avatar
Icon2 cant full throttle?
b18b1 ef hatch converted to mpfi and running obd1
ok so if im mashing it and i full throttle the car will stop revving and slowly go down but if i let off even a half an inch it goes again its really weird and happens in all gears im thinking tps but im not completely sure any ideas?
Old Jun 12, 2013 | 07:18 PM
90_EX_Civic's Avatar
Default Re: cant full throttle?
could be tps
fuel filter clogged
bad o2
throttle cable not bolted down right
cat might be clogged.
just to name a few, and this is saying that the swap was done right.
Old Jun 13, 2013 | 10:52 AM
Nick Cello's Avatar
well im getting codes 1 and 41 which sre both o2 heated oxygen sensor but all the wires are going to the right pins and ill change the fuel filter soon
Old Jun 13, 2013 | 11:30 AM
DCRB's Avatar
edit: just saw you said you were obd1. sounds tps related, you can run with no o2 sensor and still hit redline
Old Jun 13, 2013 | 12:38 PM
he wasn't talking about hitting redline. was wondering about the stumbling issue when going WOT.
which leads to the codes, you'll probably need a new o2, same for new air temp censor. wire's might be okay, but if the censor itself, is bad, you're gonna need to replace it.
Old Jun 13, 2013 | 04:41 PM
EFlovin''s Avatar
Wouldn't that make him run extremely rich(especially if he has a chipped ECU) and not pass smog?
Old Jun 13, 2013 | 05:11 PM
DCRB's Avatar
yeah the ecu would revert to the stored tables. would not run as well. I meant you should still be able to go WOT, friends eg had not o2 sensor and he smashed on it all day back in highschool.
LimaBean
Jul 26, 2009 08:39 PM
benjamin80
Honda Civic (2001 - 2005)
Sep 23, 2008 10:22 AM
zenon8890
Jun 12, 2006 03:42 PM
auto moto
Dec 28, 2005 05:45 PM
