Headlight + Taillight Removal
Old Oct 23, 2002 | 11:09 PM
Key's Avatar
Key
New User
Default Headlight + Taillight Removal
anyone have a quick site i could check out for directions on how to remove these?
My front headlights are fogged and my rear passenger side tailight has gone out, the brake light still works but the center piece has gone out. Not flattering to drive around at night in.
Old Oct 24, 2002 | 12:12 AM
GirlNALude's Avatar
Default Re: Headlight + Taillight Removal (Key)
for your front headlights, pull off your stock bumper, then i believe there are 3 bolts for each headlight. one on the side of the headlight facing out towards the fender, one at the top of the headlight on the frame, and one really hard to reach bolt below where your grill would be...just look in and towards the headlight and you'll see where it is. I used a crescent wrench and small fingers to get at that one
Old Oct 24, 2002 | 10:42 AM
Elivi8's Avatar
for the taillight, there is a cover inside the trunk that you pull off. Grab the light that is burnt out and twist the holder. It will turn a little bit then you can pull it out. Push the light bulb down into the holder and then turn it. Let go and it will pop out.
Veency
Lighting
Jul 14, 2016 01:46 AM
ryanrm20
Acura TSX
Oct 16, 2008 05:07 AM
()0()Miklo
Oct 19, 2007 01:14 PM
HondaAccordSE1997
Jul 10, 2007 05:46 AM
fiebru1119
May 9, 2002 06:03 AM
