Resurface or replace
Old Jun 12, 2013 | 09:49 AM
gobeavers08's Avatar
Default Resurface or replace
Should i resurface or replace my flywheel
Old Jun 12, 2013 | 10:05 AM
asianflava's Avatar
Default Re: Resurface or replace
Take it to a shop and have them make the determination. They can see it in 3D instead of pictures. Best case, they will say resurface it which will save you some money and you will get a little bit lighter flywheel (not by much). Worst case, they will say to replace it. Either way, you will get your answer.
Old Jun 12, 2013 | 11:05 AM
91 EF DX's Avatar
It looks like it has heat cracks in it and if so its not worth resurfacing. Buy a new one, id go aftermarket (lightweight)
Old Jun 12, 2013 | 12:43 PM
F22Master's Avatar
Well, you can get OEM type replacements from the autoparts stores for ~$50-60. Lightweight aftermarket ones usually start at double that and go up from there.
Old Jun 12, 2013 | 03:27 PM
KevinEF7's Avatar
I clicked this thread with intentions of saying Resurface, as I have done many times with success.
But after seeing your pictures, buy a new one, as said new pieces can be had for as low as $40, your flywheel has been thru hell heat and back, I wouldnt use that again
Old Jun 13, 2013 | 10:25 AM
Tyson's Avatar
new flywheels are pretty cheap.
and theyre probably a bit lighter. my OE replacement from clutchcityonline was a couple lbs lighter for sure.
Old Jun 13, 2013 | 04:39 PM
EFlovin''s Avatar
Since you already have everything opened up, just install a lighter flywheel. It will also be easier on the engine as the revs will drop quicker(and raise faster.)
Old Jun 13, 2013 | 05:12 PM
DCRB's Avatar
told you on face book, replace that
Old Jun 13, 2013 | 10:55 PM
POPLERO's Avatar
mine was similar and i replaced it with a lighter one, couldnt be happier
Old Jun 14, 2013 | 09:05 AM
Z0831xiz's Avatar
Posted from Honda-tech.com App for Android
Old Jun 17, 2013 | 03:48 PM
zrickety's Avatar
I'd recommend the fidanza flywheel, the lighter the better if you know how to drive. I have a 7lb on the B16. If you want a good used B series flywheel, pm me.
jdmsir4dr
11
Jan 24, 2012 09:57 AM
Marcos
Dec 28, 2006 12:57 PM
RACEPAK
Dec 17, 2006 07:37 AM
lowezz
Nov 20, 2006 11:09 AM
GRAVEDIGGER
Apr 19, 2004 08:27 AM
