Starts for a second, then code 8
Old Jun 11, 2013 | 09:31 PM
monster d's Avatar
Default Starts for a second, then code 8
Okay so I have a 1990 civic lx. I purchased a dpfi harness form monotech that was convereted to mpfi and had a little jumper for the injector and dizzy pins to the ecu. When I start the car, it'll act like it starts and i'll take it out of position 3, then the car will turn off, and when I try start it again, and it'll just crank until it throws a ecu code 8 which is TDC.
I looked up what this code means, and what could be the problem. Either the dizzy is bad or the car is out of time. I checked to see if the car was in time, and it came into check. The dizzy is good, because I use it everyday in my wagon. Also the pm6 we are using is the one from my wagon. So I am kinda stuck, and need some help.
Thanks
Old Jun 12, 2013 | 10:20 PM
swordofdoom's Avatar
Default Re: Starts for a second, then code 8
The wiring for the dizzy is wrong if your getting a TDC code.. Re-wire the dizzy to ECU, better yet trace the wires and make sure they are going to the right location on the ECU from the DIzzy.
Torothebull
Jun 3, 2014 07:28 PM
run for cover
Dec 18, 2011 01:02 PM
CRX Si
Jul 17, 2003 09:44 PM
wu tang
16
Apr 6, 2003 07:18 PM
