obd0 to obd1 wiring questions
by looking at my chart that came with my obd0-0bd1 ecu jumper, i know that blue, red, black, and white are supposed to be wired up to a 4 wire o2 sensor. i have the sensor but i cannot figure out what color goes to what pin on the o2 sensor. can someone point a noob in the right direction?
i have a b20 so i am not using the vtec wires: purple, and grey. but why on black does it say vtec pressure switch- o2 sensor?
so does it matter which black wire on my 12 pin ecu jumper plug goes to the o2 sensor? the 12 pin plug has 2 black wires thats whats confusing me
It looks like you have white, white, blue (or grey?), black.
Right?
Two whites are heater (doesn't matter which goes where)
Black is signal +
Other color is ground -
Try that.
If you get an O2 code then flip the the black and the blue.
Right?
Black is signal +
Try that.
Pink = Hooks to A15 on OBD0 and splices into A13 12v+ signal also goes to power up injector box also.
Brown = Ground
Yellow = Check Engine light wire on OBD0 pin B20
Black = Ground on Main relay side
You might want to double check but this should be right since its how i got mine wired up on the conversion harness.
Brown = Ground
i hooked the pink wire up to a13 and a15
brown is hooked up to a16
black is hooked up to a2
i also replaced main relay and the car wont start. it is not getting fuel to the engine. i never hear the fuel pump prime either when i turn the key. the starter will crank
1992cxcivicEG
Dec 18, 2009 07:42 AM
Ls1 FD3s
Aug 27, 2007 06:44 PM
nabin
Mar 16, 2007 03:11 AM
