LS Vtec LMA's Issue
Old Jun 11, 2013 | 11:41 AM
JGVLSV's Avatar
Default LS Vtec LMA's Issue
Anyone know the oem Honda part number for "LMA's"... Having trouble finding the spring version of them and not the old cylinder type. Also does anyone know if there's an aftermarket type that would work just as well if not better?
Old Jun 11, 2013 | 11:53 AM
JuggerNaut-CTR's Avatar
Default Re: LS Vtec LMA's Issue
skunk2 has the spring style for $89.99
can also use h22 lma's ($8 a piece from Honda) but need a shim.
http://cms.skunk2.com/id/923/B-Serie...tion-Assembly/
Old Jun 11, 2013 | 12:14 PM
JGVLSV's Avatar
Thanks man!
Old Jun 12, 2013 | 08:40 PM
ThE HeLLRaZoR's Avatar
Part number for my b18c springs was 14820-PCB-305, if I remember correctly I think they were $15/ea. I paid around $200. I highly recommend you try Skunk2. Mine are great but, **** the Dealer.
For sure do everything you can to replacing the old garbage type lma for sure!
Old Jun 15, 2013 | 11:31 AM
JGVLSV's Avatar
Well I've replaced them, on first startup I still have the same knocking sound... Any reccomindations???
Old Jun 18, 2013 | 05:31 PM
JGVLSV's Avatar
Valves have been adjusted. I'm at a loss, I don't know where to go from here... ANYBODY?!?
Old Jun 23, 2013 | 08:10 AM
h22god's Avatar
Ignition timing? You haven't bent any valves have you? Did you do the timing belt lately and perhaps. Are off a tooth on the mechanical timing? And your sure you adjusted the
Valves precisely? Are you sure the valve springs have not worn out of OEM seat pressure
Spec? So much it could be. For all I know it could be a bad distributor shaft clunking around.
Lol more info would be nice.
97CWITR
Jan 10, 2018 06:38 PM
FOC-US2K
39
May 3, 2009 08:21 PM
panchovilla760
Feb 27, 2007 05:41 PM
DOHCtorTHRUST
11
Mar 15, 2004 12:14 PM
honda8882
Apr 22, 2003 06:07 AM
