97 hatch fuel pump won't prime
Old Jun 11, 2013 | 10:55 AM
pgh-tsx's Avatar
Default 97 hatch fuel pump won't prime
Like the title says my fuel pump won't prime at first, eventually it will. It can take anywhere from 1 minute to 10 to eventually prime. I figured it was the main relay but I replaced that and it still does it, I checked all the fuses too. It's converted to obd1, don't know too much about that and im not sure if that would matter with this problem.
Old Jun 11, 2013 | 11:08 AM
pgh-tsx's Avatar
Default Re: 97 hatch fuel pump won't prime
And the cel stays on until it primes, don't know that means anything either.
Old Jun 12, 2013 | 08:47 PM
pgh-tsx's Avatar
Nothing? Not ideas?
Old Jun 13, 2013 | 11:56 AM
SolScifen's Avatar
The cel will stay on if there's no fuel pressure.
It could be wiring or a bad ecu.
Old Jun 13, 2013 | 06:15 PM
fcm's Avatar
fcm
Old Fart
Ditto the above, most likely a bad ECU/ECM, or possibly a wiring issue.
Start by confirming you have power at IGP1 and IGP2, [the only yellow/black leads at the ECU/ECM] as soon as you turn on the ign. switch to the run position.
If good, check for a ground output on the green/yellow, [fuel pump relay control, or FLR]at the ECU/ECM, the only green/yellow at the ECU/ECM, you can also test for the ground on the green/yellow at the PGM-FI Main Relay, also as soon as you turn on the ign.
You must use a multimeter for testing the green/yellow, a 12V test light, [unless it is an LED type]will turn on the fuel pump relay. 94
DeLorean00
Sep 7, 2019 09:54 AM
Bushybob94
Jun 5, 2018 11:40 AM
91integraLSVTEC
Sep 22, 2011 12:03 PM
krysted9354
20
Apr 8, 2009 03:32 PM
turbocivic96
Mar 15, 2004 12:35 PM
