Honda Civic 99 Check Engine Alert
Old Jun 10, 2013 | 05:34 PM
diar48's Avatar
Default Honda Civic 99 Check Engine Alert
I bought an used Honda Civic 99 , 2 door coupe with around 170000 miles, thought i could be able to get some practice driving before I but a new car after 6 months.I paid $ 2000 for that.
After 2 weeks, I saw the Check Engine Alert, took it to a neighborhood workshop, they charged me around $ 700 to fix the serpentine drive belts, power steering fluid flush, transmission fluid flush, brake fluid and 2 tires. The Check Engine was off for only two days. I saw this alert again , this time took it to the Honda Dealer Service station.
They diagnosed the problem and advised that need to Replace Engine Head (1999) along with engine manifold, head gasket, head bolts, cam seal, distributor O Ring, oil change, coolant service, intake manifold gasket, exhaust manifold gasket, valve adjustment with gasket adjustment, spark plugs, timing belt service.
This cost me around $ 1500 , so the total cost came up to $4300. So based on all the information, what do you think guys, should I go forward and manage , or it will be a whole down the drain expenses?
I am a novice, so appreciate your help
Old Jun 10, 2013 | 05:57 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Honda Civic 99 Check Engine Alert
Maybe you should say what code it is the CEL is trying to inform you of. You can do this with 5 minutes and a paperclip. Look in the FAQs on how to pull a code.
And I advise you to take that car to another shop. They took advantage of you and ripped you off.
Old Jun 10, 2013 | 06:13 PM
diar48's Avatar
Thanks for your response. Yes the previous station told me it will cost me $700 dollars to replace the engine head
Old Jun 10, 2013 | 06:16 PM
The Grumpiest
Again, they ripped you off big time. And the Honda guys are trying to do the same thing. I've never seen a code or codes that require that much to repair.
Do the things at this link and you'll know what codes you're throwing.
How To Pull CEL, D4, SRS, and ABS Codes
Old Jun 10, 2013 | 06:59 PM
B_Swapped93's Avatar
need to post code, and holly efff ! you got ripped of extremely hard i feel sorry for you
Old Jun 10, 2013 | 08:16 PM
EJ8mike's Avatar
Alot of that stuff is maintenance that they r getting you on. Probably nuttin to do with the code. They will take u to the cleaners if u let them!!
Toimimou
Honda CR-V & Element
Nov 21, 2018 09:23 PM
Tim1959
Honda Civic (2001 - 2005)
Jun 27, 2018 01:51 AM
Saratoga11
May 22, 2017 02:25 PM
VAryda
Jul 20, 2016 10:30 PM
NZuercher
Engine Machining & Assembly
10
Jun 6, 2015 08:42 PM
