Idk what's wrong with my car
I need help figuring out a problem. My car feels like the rear tires are loose but they aren't. It makes like a jumpy feeling as if they were loose but they aren't. Idk what the problem could be? Any info would be appreciated.
It's a 91 ef hatch. Rear disk conversion. I didn't have this problem before. My car had been on jack stands for the past week. I just also changed the axles.
The rear of the car wasn't messed with at all and this happens -____-
its most likely your rear trailing arm bushings they might have never been changed and very old. factory old.
pretty simple to change.
just need a press to pop them in.
Posted from Honda-tech.com App for Android
If I'm right the car starts like shaking once you hit between 55-70 MPH but once you go over it stops. its not all bad but could be dangerous if it is never with and ignored.
put it back in the Jack stand, rotate tires, repeat this post but replace rear tire with front tire, sounds like a bubled tire. look at your tires.
88 civic ef
13
Jan 2, 2008 04:31 AM
Lui Kang
Jan 15, 2002 05:30 PM
