Honda CR-V & Element 2WD & 4WD Element & CR-V
honda element 2007
Old Jun 10, 2013 | 04:37 PM
still tongue's Avatar
Default honda element 2007
hi I've had my Honda element since the very beginning I've never had no serious problems with it until just a few weeks ago. My element started over heating when I would b going up hills. So I went ahead and start checking on some parts on the vehicle I observe that the fans wasn't working so I change both fans. Then I change the radiator and thermostat. I also observe that one of the hose had a leak so I change that too. Now I'm trying to find out if the head gasket or what else might cause my vehicle to overheat and if its the gasket is there a way u can tell if its blown........very frustrating
Old Jun 10, 2013 | 04:44 PM
Sticker Bomb's Avatar
Default Re: honda element 2007
Normally if the head gasket is gone, if you are to open the rad cap it will look like vanilla pudding in the rad and cap from the coolant and oil mixing.
It could also be overheating from a coolant temp sensor being bad.
It could very well be the new thermostat you just installed. I replaced mine because my old integra was over heating, and the new thermostat was faulty, so I just cut the middle out, and never had a problem again.
Old Jun 11, 2013 | 08:43 AM
microcraft's Avatar
Do your fans turn on at all? I'm betting both of your original fans weren't bad. Sticker Bomb has a good idea of the temp sensor. If sensor is faulty - the fans never get told to turn on. Also running it w/o the thermostat in is a good test too.
You can test your old fans by putting 12V to the terminals. Man, I'll bet you dumped some ca$h into a new Rad and fans.
mc
Old Jun 11, 2013 | 05:51 PM
ok sticky bomb if I take out the thermostat I think the check engine light would come on cause with these new cars I think there made to do that. so if that works and the check engine light come on then what do u recommend
Old Jun 11, 2013 | 05:57 PM
yes microcraft both fans are working and the old fans had seize up that's how I knew they were bad.....yes I did spend a few bucks in the car lol
GSD
Oct 29, 2017 04:33 PM
taylor67
Mar 23, 2017 01:23 PM
ltapia707
Honda Civic (2001 - 2005)
12
Mar 19, 2013 02:57 PM
ej2redcoupe
Aug 1, 2011 06:24 PM
spruman03
Jul 6, 2008 11:40 AM
