Honda civic b18b1 upgrades?
Guide to Answer the Common Question: Just Bought a Civic! How Do I Make It Faster?
it all depends on your budget and what you intend on using the extra power for..
Head swap is a pretty simple ordeal or save a bit and boost that b18b1 and make more for less than the N/A lsV. don't try and do many bolt on's with a b18b1 it's not worth it.
a b18 is about as powerless as the d16 just with a tad more torque... I recommend boost if u plan on making more hp per dollar spent... bolt ons and a head swap would not net u much with a stock bottom end. if u plan on doing a head swap u need arp rod bolts to rev it out more which that crank is not balanced to do like a gsr or b16 crank...
xXSiGuyXx
10
Jun 26, 2005 08:31 PM
