d16z6?
Old Oct 23, 2002 | 09:42 PM
neutron91's Avatar
Default d16z6?
my d16a6 motor in my 89 si is pretty much gone... i know where i can get a complete d16z6 motor for a good price... will i have to do an obd0 to obd1 conversion or can i just switch over the parts on my old d16a6 to the d16z6 and make it work properly... if so, what all do i need to do?
Old Oct 23, 2002 | 09:57 PM
MrTodd's Avatar
Default Re: d16z6? (neutron89)
Basically the Z6 is pretty much the same motor as a A6 - but it's OBD-1, and has VTEC.
So what I'm saying is that it's a direct bolt-in... almost...
(If you stay OBD-0)
As for mounting one of those beasts, you'll need to transfer the entire drivers side motor mount from the A6, to the Z6 - and lose the L-shaped bracket. Bolt up the Si tranny to the Z6 block (maybe use the Z6 clutch as well, A6 clutch will work too). Then transfer your Si wiring harness to the Z6 block - everything plugs right in except for one connector... You'll notice that the thermostat housing has a wiring plug in it - the two wire sensor on the back of the A6 block is relocated to thermostat housing on the Z6 block. You'll have to custom fabricate the wiring to plug in there (easier if you have a Z6 wiring harness). Put on your old Si distributor (nasty fit), and your Si injectors.
Then just drop it in, and get it running using the PM6 ECU (for now).
Once you have all the bugs worked out, then you can worry about vtec activation - I recommend getting a Zdyne one-wire conversion (I just ordered mine), you'll get nice beefy fuel maps, and all the goodies of an OBD-1 ECU (minus the VSS functions! )
[Modified by MrTodd, 11:58 PM 10/23/2002]
Old Oct 23, 2002 | 10:01 PM
neutron91's Avatar
Default Re: d16z6? (MrTodd)
should i use the intake manifold from the z6 or a6... distributor?... etc... thanks for the info above
Old Oct 24, 2002 | 05:46 AM
USDM 4G VTEC's Avatar
click my sig
i have all info about my Z6 swap in there
go read and search a little... theres a bunch of info here
Old Oct 24, 2002 | 06:39 AM
neutron91's Avatar
Default Re: d16z6? (JDM EF9)
thanks yet again... i think im gonna go for this setup for now... its cheap and seems to get decent gains compared to my d16a6
Old Oct 24, 2002 | 09:38 AM
slywfbpsi's Avatar
your link isn't working
Old Oct 24, 2002 | 12:47 PM
EFSiR's Avatar
I'd get the JDM DOHC ECU for SOHC VTEC motor. I used it for 6 months and loved it. If you ECU is not chipped, you need a Knock sensor, and 2 oxygen sensors in the A-pipe as close to the header as possible.
Look at this...
http://www.angelfire.com/ca/DrOhm/hybrid.html
Ej1 honda
Jan 9, 2012 03:23 PM
Neutex22
Jul 15, 2004 02:33 PM
bhummel
14
Nov 13, 2003 10:48 AM
dingusjt
Apr 27, 2003 12:32 PM
Kato7997
Mar 5, 2003 01:51 PM
