FS: D16 Edelbrock Fuel Rail and DSM 450's w/ resistor box
Old Jun 9, 2013 | 09:52 PM
sam311's Avatar
Default FS: D16 Edelbrock Fuel Rail and DSM 450's w/ resistor box
$75 for the injectors with resistor box.
$100 for the fuel rail with all fittings brand new in box.
-or $150 for both the rail and injectors.
Set of four (4) DSM 450cc blue-top fuel injectors with clips, and a wired resistor box. I bought these used and replaced the o-rings, seals and mounting grommets and wired up the resistor box.
Brand new, never used Edelbrock Pro-Flo Fuel Rail for 1996-00 Honda Civics, part # 4799. I was going to use it on my turbo application but have decided to use a different fuel setup. I only mounted the hardware up and a fuel pressure gauge to check fittings and such but it is otherwise brand new and in box.
Item description from Edelbrock:
Designed for stock or Edelbrock manifolds, these Fuel Rails are fully CNC machined from aluminum extrusions, polished then hard anodized for use with racing fuels (including methanol). The 5/8" i.d. fuel passage features a flow-through design with 8 AN o-ring threads on both ends. These Edelbrock Fuel Rails include a fuel regulator mounting at the end of the rail that can be used with stock or aftermarket regulators and two auxiliary 1/8" NPT ports for pressure gauge, nitrous system fuel supply, etc. All hardware is included for an easy installation.
Located near Hunting Beach, Ca.
Please call or text Sam: 562-280-eight-five-nine-zero
billy hoang
Northeast (Sales)
Feb 17, 2011 10:11 AM
billy hoang
Northeast (Sales)
Dec 6, 2010 09:33 AM
spooolin
Oct 13, 2006 07:48 AM
