FS 99 d16y7 long block/transmission.. 96 d16y7 head..
Old Jun 9, 2013 | 07:16 PM
billys_da_integra's Avatar
Default FS 99 d16y7 long block/transmission.. 96 d16y7 head..
UP for sale guys.. a complete D16y7 LONG BLOCK.. less tahn 10% leakeage in each cylinder!.. healthy. WILL PROVIDE A LEAKDOWN test to purchased to prove it holds compression and no bad rings or valves.. im asking 300 for it.. 120k original miles when pulled from 99 civic DX.. clean vins.. paper work will be included as well. comes with complete INTAKE manifold.. distributor.. alternator.. ECU.. ALL sensors included... NO exhaust manifold. water pump is leaking... bad gasket. timing belt is good. im taking the bad water pump into consideration so i am asking - $350 firm (will replace for buyer if they provide the new waterpump same day they pick up motor at no extra cost)
D16y7 transmision.. 5speed transmission clean vin.. paper work included.. shifts like butter.. no grinds.. no bad bearings noises 120k.. drove it myself before motor was pulled. exedy daiken oem replacement clutch included.. 15k on it.. great clutch. oem flywheel included.. clutch fork release bearing included - asking 200 firm
UP FOR SALE i ALSO HAVE A D16y7 HEAD.. came off a running 96 civic DX.. owner gave it for me when he supposedly went VTEC.. mini me conversion. head internals are complete.. what you see is what you get., no distributor.. not intake manifold.. - 60firm
questions text 310 four six two 5054 - will
gelok
Nov 16, 2014 08:05 PM
guymosiris
Jul 6, 2008 06:03 PM
DOHC_C-REX
Oct 8, 2006 12:49 PM
E46M3CB
Mar 12, 2004 10:42 PM
