Transmission & Drivetrain Gearboxes, Differentials, Clutches
obd1 hydraulic trans swap in ef, speedo?
Old Jun 8, 2013 | 06:24 PM
crxtech87's Avatar
Icon2 obd1 hydraulic trans swap in ef, speedo?
my research shows that i can swap out the vss sensor and drop in my vss cable no problem. but, does the ecu need to see the vss and i would imagine it would set a dtc for vss no? thanks
Old Jun 8, 2013 | 06:26 PM
crxtech87's Avatar
Default Re: obd1 hydraulic trans swap in ef, speedo?
i should say its a complete obd1 swap, b16a in particular
Old Jun 8, 2013 | 06:41 PM
crxtech87's Avatar
further research shows that the vss code can be removed with chrome and the vss code can disable vtec. but i was hoping i wouldnt have to run chrome since i will be running a stock swap and dont want to have to chip and tune the stock engine. i guess the questions will be... is there another way to do this (minus cluster swap) and, is there a base tune available for a stock b16a gen 2 from chrome?
Old Jun 8, 2013 | 07:05 PM
Black R's Avatar
25 Year Member
Yes, you can run a base tune for a b16 no problem.
Idk if there's another way, but who cares bc you'll get better power and fuel economy if you chip and tune.
Old Jun 8, 2013 | 07:10 PM
crxtech87's Avatar
ok thanks. maybe that is the way to go. a little extra time and money but i suppose its the best option
Old Jun 12, 2013 | 03:58 AM
rd91sib18c5r's Avatar
My cay is obd0 and I'm Using an obd2 ecu, I have the stock vss in the tranny the sensor
is in the guage cluster.
91gsrx
Sep 6, 2012 04:51 PM
EF OBD 0
Jul 31, 2011 12:28 AM
acuratech
Mar 6, 2005 07:20 PM
toslowhatch
Nov 18, 2004 02:35 PM
dingusjt
Feb 11, 2003 06:34 AM
