15x7 et25 on eg civic - and no, i don't want "stance"
pondering what the fitment would be on an eg hatch with a 15x7, et25 and a 205/50 15 tire.
i'm not after stance or any poke - i simply like "full" looking wheel wells.
will this poke past the edge of the fenders? can't find any pics of this setup, yes i googled.
thanks...
thanks...
Will you be running any negative camber? If running at 0 degrees, you will have slight rubbing issues on stock sheetmetal. You'll clear the sheetmetal if you roll the quarter panels and fenders a little bit.
toyomatt: i'm fixing to buy new fenders, and run 15x7 +42 with some 225/45/15's will I need to roll the fenders? currently i'm running some 225/50/16 and they are to gosh dang big. my car is a 99 civic coupe
Check this:
https://honda-tech.com/tire_rim_calculator.php
225's are a bit wide for 7". Just run a 205/50/15 in a better compound.
Check this:
Check this:
With a 15x7 +42, you're going to get pretty close to your knuckles up front with 225's. I'm not 100% certain if they'll clear the suspension with that offset or not. You should be able clear exterior panels with very minor camber or rolling the fenders/quarter panels.
PS. Just make a new thread next time.
No need to threadjack here.
thanks for the imput guys, and i saw you answered the OP's question and i didn't want to clutter the forum with another thread! but thank you for the advice.
Check this:
Check this:
225/45/15's are rated for 7-8.5" wide wheels. So, although a 7" wide wheel is the most narrow wheel you can run safely with 225/45's... its still plenty safe.
No need to threadjack here.The reason I recommend a 205 on a 7" rim is because the actual contact patch doesn't improve with a 225, the floaty feel of the rim moving laterally inside the tire can be unsettling, price goes up for a 225 vs 205, and fitment issues get harder to overcome.
I can tell you that a 225 with that offset will clear up front on the knuckles, but not on the rear trailing arm - you might also have to notch the rear camber arm to clear the rim.
For a 225, you'll want around a +35 to clear the trailing arm.
Keep in mind that the actual dimensions of tires vary by manufacturer - regardless of size markings.
toyomatt is correct - the rims/tires fit and sit flush with the fender wells. no rubbing issues either, and did not have to roll/pull fenders as my car is stiffly sprung.
thanks!
thanks!
smh at 225 on a 7 wide... that's too skinny of a wheel. I am running 225s on an 8' wide and i wouldn't ever run it on anything thinner. imo, 7" is good for a 205.
From: Pensacola, FL and every Court House in Louisiana
195/50 is oversized and with throw the speedo off. 195/45 would be the correct size to use.
I am running 15x7 +36 enkei's on my hatch w/ 205/50 Z1 starspecs. I had to roll my fenders. Plenty of pics in my build thread link'd I my sig.
eghatchback94
Sep 28, 2012 09:15 AM
Kenji M
19
Aug 16, 2006 08:50 PM
