crx dies when i take off spark plug wire on #2 cil
Old Jun 8, 2013 | 01:54 PM
Crxh22ajdm's Avatar
Default crx dies when i take off spark plug wire on #2 cil
OK so I just buy this bone stock Crx si. And I was just checking for good spark on wires and when I took off the wire on cil#2 the car died. I turn on the car and try it again and same it died again. What can be the cause of this?? Thanks in advanced
Old Jun 8, 2013 | 03:59 PM
92 civic ex 4dr's Avatar
The cause is that the number 2 cylinder is no longer firing.
Include more detail I'm not sure what your getting at. The car dies. Does it stutter and die slowly? Or just instantly
Posted from Honda-tech.com App for Android
Old Jun 9, 2013 | 12:29 AM
Crxh22ajdm's Avatar
Default Re: crx dies when i take off spark plug wire on #2 cil
It dies when I take off the spark wire out of the spark plug. When its not doing any contact. Also it only dies when I take the spark plug wire on that Cil. (#2)
Old Jun 9, 2013 | 06:32 AM
Crxcam's Avatar
when the wires are all in does it sound like its missing at all on any cylinder?
Old Jun 9, 2013 | 06:44 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you are going to burn up your coil doing that, with the car off you need to ground the wire from that cylinder then see if it makes a difference when you start it, a grounded wire won't hurt the coil, but an open circuit will
Old Jun 12, 2013 | 04:15 PM
Crxh22ajdm's Avatar
It sounds all good. Also the car starts rigthup. The milage is 180,300 and has good compression I still can't find the problem
Old Jun 12, 2013 | 04:21 PM
Crxh22ajdm's Avatar
Ground the spark plug wire, how? Can you give me a lil bit of more details of how to do that thanks
Old Jun 12, 2013 | 05:19 PM
Um clip it to something metal, other then anything with fuel in it, an open circuit with the coil can build up much higher voltage then normal in the windings and can destroy the coil
PsXtreme
Jun 26, 2016 01:43 PM
dabeast111
Jun 5, 2011 08:43 PM
imroadk1ll
Mar 23, 2010 04:21 PM
vsmftw98
Aug 4, 2009 02:14 PM
slowd16z6
Mar 13, 2004 07:12 PM
