90 HF wiring issues
Old Jun 8, 2013 | 09:41 AM
Red_ED8's Avatar
Default 90 HF wiring issues
OK H-T I need your help. I've been trying to finish up my wiring (obd0-obd1 + misc) and the more hours I sit here and look at diagrams the more unsure I am. I need to find a diagram on the pass side connectors. I have diagrams, just non that show the connectors. I have a 90 HF (A6 with Y8 head) that was been abused by a previous owner (electrical tape and butt connected everywhere) and could use some info. I switch over to a obd1 thermo housing with the fan switch on it and need to know what A) connector 6, 8, or 14 and B) pin position. Lastly is the coolant temp switch on the head. Which connector does that run to? The 8 or 6? Luckily I have a obd1 and 2 engine harness laying around to steal from but the original hf harness is done for .
Old Jun 8, 2013 | 11:35 AM
Red_ED8's Avatar
Default Re: 90 HF wiring issues
As far as I can tell the single wire temp sensor on the head should be yellow with a green strip but I've found 2 yellows with a green strip? One on the 8 pin strut tower connector and one on the 6 pin? I take it one is for the coolant temp sensor and one for the switch but which is which?
G-power
Oct 9, 2014 08:00 AM
6 Star
Apr 23, 2013 07:18 PM
madgeo
Sep 19, 2010 03:52 PM
Malgerus
Jul 13, 2008 10:34 AM
hksdrager
Apr 5, 2007 01:59 AM
