to do a 4 disk brake swap...
Old Jun 8, 2013 | 09:16 AM
89ED's Avatar
Default to do a 4 disk brake swap...
is it the da setup that will only fit?
Old Jun 8, 2013 | 09:57 AM
lopa's Avatar
Default Re: to do a 4 disk brake swap...
Usually people go with the DA rear disc, or CRX Si rear disc. The whole setup from a DA will bolt right up tho, but with a CRX you will need e brake cables from the DA. I just did this conversion from a 1990 DA and used everything, trailing arms, brake lines, e-brake cable, ect. The e-brake cables bolt right up too so theres no issues there.
Old Jun 8, 2013 | 12:23 PM
91 crx hf's Avatar
On a crx, you need to use the toe arm from a crx, not DA.
Also, the DA ebrake cables are like 8-10" longer, kind of a pain to deal with, but usable.
Old Jun 8, 2013 | 05:04 PM
89ED's Avatar
i have a ef sedan so lets get the clear
i found this. can i do this to my ef sedan?
http://www.superhonda.com/forum/f14/...linder-354472/
Old Jun 8, 2013 | 10:20 PM
89ED's Avatar
Old Jun 9, 2013 | 01:18 AM
lopa's Avatar
DA E-brake cables are only too long for the crx, and since he has a sedan he should be fine with DA e-brake cables. IMO to the OP, go to a junk yard, find a DA, and take everything on the trailing arm except the arms. This is all you will need from a DA
E-Brake Cables
Trailing Arms with everything on them, rotor, hub ect.
Brake Lines
***DO NOT USE DA ARMS*** the camber and toe arms are not the same for EF.
Also since your an 89 I think they still used different LCAs than 90 and 91 civic so you will need the LCAS from 90-91 civic as well.
For conversion from a CRX you want
DA E-Brake Cables
Brake lines from a DA
Trailing Arms from CRX and hubs rotors ect.
Essentially either way you need the DA brake lines and cables since they will bolt right up, crx lines and cables are too short.
I just did this conversion and all I changed was the pads on them. I didn't up the master or the prop valve, its highly recommended but not 100% required for daily driving.
Old Jun 9, 2013 | 04:54 AM
Deetz's Avatar
Crazy Honda Guy
Do your research before doing this swap. I was all excited about it myself and had it done a decade ago....but, looking back, i regret it.
Doing this conversion will give you zero added performance, it is simply for looks. On a typical Honda, 75% of the braking is done in the front anyway, the rear play a small role in helping keeping the car balanced, and because these cars are so light, the drum setup do the job just as well. In fact, back in 1990, when the new refresh of the crx si came out with the rear disk setup, it stopped 3 feet longer than the previous 88 and 89 model with the drum setup, LOL
So again, i think......i spent money, i used my time, i added weight to my car, and gain no performance...but it looks good
Old Jun 9, 2013 | 05:08 AM
crxguy406's Avatar
omg... THANK YOU! I got a little razzing on my build when I kept the stock drums, they didn't believe me when I said it really wasn't worth the extra work/money.
Old Jun 9, 2013 | 06:00 AM
M-benz's Avatar
Well said !
Old Jun 9, 2013 | 06:07 AM
nmoreira3's Avatar
yes i feel the same way i spent a couple of hundred dollars doing this swap and i dint see
any improvement
Old Jun 9, 2013 | 08:18 AM
th3pwn3r's Avatar
Drum brakes are also a pain in the *** to change in comparison to disc.
Old Jun 9, 2013 | 11:02 AM
89ED's Avatar
i have a 90 sedan but i created this account when i had a 89. so no added performance just looks. im ok with that. half off sale is coming up at my nearby junkyard anyway. but ive read that civic disk brake trailing arms are 7lbs lighter each. so would like to find those if they will fit.
could i use the da lca's with adjustable uca's and camber bolts and have nice stance?
Old Jun 9, 2013 | 11:21 AM
Deetz's Avatar
Crazy Honda Guy
lol, one is not much hard than the other to change than the other. Also, this is something that gets done, what? ....every ten years ;P It's really not much of an inconvenience
Old Jun 9, 2013 | 12:21 PM
V.MoMO's Avatar
actually its the other way around, disk brake set ups are 7lbs heavier each side. there might not be much to no performance gain but in heavy braking it does reduce the nose dive a car does. annnnnd it also looks good lol
Old Jun 9, 2013 | 01:02 PM
89ED's Avatar
i thought i read that the trailing arms from a civic with stock rear disk are 7lbs lighter than trailing arm from a da with rear disk
Old Jun 9, 2013 | 01:05 PM
lopa's Avatar
Id by UCA you mean the camber arms then sure, theres no camber bolt like in the front, usually the rear is an arm that can either extend or compress more to add or reduce camber.
I also wouldn't use the teggy LCAS. If you have a 90 sedan you don't need to you can just use the ones you have. The only reason I said get new ones is because 88-89 use LCAs that are different and kind of "bock" style
Old Jun 9, 2013 | 01:49 PM
89ED's Avatar
Old Jun 9, 2013 | 03:23 PM
lopa's Avatar
Did you read through that whole thread though? You don't need to have 15" brakes. Also this topic has been covered to death, you could search and find threads on this already
http://hondacrx881.tripod.com/discbrakes.html
http://www.clubcivic.com/board/showthread.php?t=43353
http://crxcommunity.com/viewtopic.php?t=13990
Read through these threads and you should find most answers to your questions...
Also what are you wanting to do? From the looks all you wanted to do was swap to disc brakes, but you qouted that thread with the 15" brakes so did you want bigger brakes after you swap to rear disc?
Old Jun 10, 2013 | 08:32 AM
V.MoMO's Avatar
trailing arms dont change, theyre all the same. what chages are the hubs. the drum hub setup is lighter than the disk hub setup. so both cars have ideally the same weight with the same setup.
when i did my swap in the back all i did was switch the hubs, didnt even mess with the trailing arm. most people dont do it this way because they dont know that all trailing arms are the same
Old Jun 10, 2013 | 11:58 AM
89ED's Avatar
siiik is it harder to get the hub out as opposed to take whole assembly
Old Jun 10, 2013 | 02:12 PM
crx_si-r's Avatar
correct me if im wrong, but didnt the 88 si also weigh less than the 91. this also has to be taken into consideration
Old Jun 10, 2013 | 02:38 PM
th3pwn3r's Avatar
Yep, CRXs got fatter every year after the 88. Same when going from HF to Si as most people know. I really want to buy an 88 HF and strip it down until it's about 1600 pounds and daily it until I get in an accident which would make it look like a pop can you just stomped on.
Old Jun 10, 2013 | 05:20 PM
Deetz's Avatar
Crazy Honda Guy
you are correct! It had stamped steel rear lower control arms, much less than the cast ones found on newer models. The 89 model was a few more pounds because of this.....then the 90-91 models were more because of the rear disk setup (Si models)
Old Jun 10, 2013 | 06:59 PM
blk_honda112's Avatar
Seriously ... Why convert if you can just use scarebird brackets . http://scarebird.com/index.php?route...product_id=116
Old Jun 10, 2013 | 09:15 PM
crx_si-r's Avatar
Because I prefer to change or all out. I picked up an entire DA for $100 still cheaper than those adapters. Lol
