Car cover useage?
My 95 del Sol is now without a garage for the first time!
I have an Evolution 4 breathable car cover. What are the pros and cons of using it outdoors, in a climate with lots of rain?
The original paintwork is mint, and I'd like to keep it that way.
Cheers, Senior Sol
Cheers, Senior Sol
From: Pensacola, FL and every Court House in Louisiana
I have always feared scratching my car due to being dirty so I only use after car has been cleaned and will be sitting up for a period more than a week otherwise I just wash and wax 1-2 week
I think a good coat of wax and regular washing is a better idea personally if this is a dd and your just being **** about the paint and always being in a garage. Your more likely to scratch and damage the paint if your rubbing something (car cover) across the paint twice a day.
The car is not a dd....often it sits in the driveway for up to a week. I basically drive it on sunny weekends.71,000km on an 18 year-old car, that says it all.
I am **** about the paint, and whining about not having a garage...guilty as charged.
Think I'll continue to both wash and wax it regularly, AND carefully use the (clean) car cover, when it's parked.
Two further questions......being lazy, I often use the local coin-operated brushless car wash...will using their "high-pressure" hose actually strip off the wax? Are their soaps too harsh, and also likely to damage the paint?
Thanks again.
Senior Sol
Yeah in that case I would use the cover. I tend to use the brushless car washes myself especially when traveling with work and never had a problem so far. I am sure they all use different product so the chemicals will vary. I tend to use a wax as you dry product after running through the car wash or at home just to be on the safe side. I tend to be **** myself with my car
I'm SHOCKED!!
The car just spent a wet week under the car cover. When I removed it today, it was VERY filthy.
Don't know how the dirt got into, or under the cover, but the car was MUCH dirtier than if I had left it exposed to the elements.
That's it for me....no mas car cover.
Cheers, Senior Sol
Cheers, Senior Sol
I'm shocked to see my car not dirty after a good week of rain. Untouched from water stains. Its not the expensive type cover. It was made by Classic assessories "overdrive Polypro 3" from Amazon. 30 bucks.
W0P
Mar 19, 2004 07:57 PM
