Help with 2000 Honda Civic DX Check Engine Codes Please !!
Old Jun 7, 2013 | 02:06 PM
BCarignan4892's Avatar
Default Help with 2000 Honda Civic DX Check Engine Codes Please !!
Today i got in my 2000 Honda Civic DX Automatic and its raining fairly hard.
Usually it starts up right away but this time it needed one more turn, suddenly my check engine light came on, didnt really think anything of it because i thought it was just because of the rain.
I went to autozone to check the codes and they came up as...
P1753 (Automatic Transmission Lockup Solenoid A Malfunction)
and
P1381 (Camshaft Position (CMP) Sensor A Intermittent Interuption )
When i was driving for awhile it was running fine till suddenly the "D4" icon on the dash started flashing, then my car wasnt driving properly, it would feel like its in neutral but itd be driving at like 3 mph, so id pull over and restart the car and it was fine. after trying to go home and restarting my car multiple times it kept happening ever second till i couldnt really drive so i parked at a gas station, i turned it on again and put it in reverse and the car pulled itself and slammed then i put it into D4, and it was driving at neutral.
Keep in mind its raining fairly hard, not sure if it has anything to do with it. but yeah.
Im very grateful to any help, please and thank you.
Old Jun 7, 2013 | 09:17 PM
apexi_rsx's Avatar
Default Re: Help with 2000 Honda Civic DX Check Engine Codes Please !!
sounds to me your trans is toast... was the trans slipping at all before all this happened? that's the thing with automatic wet clutches when one gear goes they all go and it acts like it in neutral.
Old Jun 8, 2013 | 03:28 AM
HondaPartsHero's Avatar
Technical Hero
Could be that the rain water got into some connectors especially if you don't have any splash shields so check that as well and dry them out if so
Check the CYP (1381)
And 1753
AllOutBeard
Apr 21, 2017 05:42 AM
Himynameismatty
18
Nov 21, 2015 04:43 PM
AdamBl
Apr 27, 2011 07:41 PM
myr10
Jan 30, 2011 03:37 AM
Flat6
Sep 15, 2007 10:45 AM
