FS:Civic Parts &Turbo Parts & More
Old Jun 7, 2013 | 08:15 AM
SlaminSohCivic's Avatar
Icon3 FS:Civic Parts &Turbo Parts & More
Got Some Parts Forsale
Located :New Salem ,PA
-Tial Blue 38mm External Wastegate....1 Bar Spring....Great Working Shape....$135.00 Shipped
-HKS Bov Flange On Pipe of Piping $12.00 Shipped
-OBD2 P2P Y8 Ecu $45.00 Shipped
OBD0 PR4 Manuel Ecu $50.00 Shipped
-OBD0 PG7 D16A1 ECU $40.00 Shipped
-OBD2 P2E Y7 Auto ecu $30.00 Shipped
-OBD1 P07 Manuel Ecu For parts $15.00 Shipped
-D16 Ramhorn Turbo Manifold....WG Flange Cut Off...But im Including a 38MM 2 Bolt Weld on Flange or u Can Put a V Band on it.....Manifold is Not Cracked
T3 &T4 Flanged Has 2 Broken Bolts on Flange Parts...But u can See both sides...Easy Out
$45.00 Shipped Wit Flange
-B-Series AEM Style Adjustable Cam Gears...Great Condition....$40.00 Shipped For Set
-OBD2B to OBD1 Ecu Jumper Harness.....1 Pin is Pulled Out $25.00 Shipped
-D16Z6 3 Bolt Style Aluminum SI Mount &Bracket $45.00 Shipped
-B18C1 3 Bolt Style Aluminum GSR Mount &Bracket $60.00 Shipped
-PR3-3 Completely Bare Vtec Head....Perfect For a Big Build....What you See is What u get...All Cam Jernouls Are Nice...Combustion Chambers Are Clean..$110.00 Shipped
or $170.00 Shipped For Head wit Valve Cover
-TOP Cam Set is 99 si B16A2 Cams 91k Miles $60.00 Shipped for Set
-Bottom Cam Set 91 CRX SIR B16A Cams 108k Miles $50.00 Shipped For Set
-B16A Vtec Solenoid....Perfect Condition $65.00 Shipped
-D16Y8 Vtec Solenoid.....$35.00 Shipped
-Civic,Integra Map Sensor $35.00 Shipped
-Othe Map Sensor Off K 20 Wit Pigtail $45.00 Shipped
-B18C1 Knock Sensor $33.00 Shipped
-99 Civic IAT Sensor///With Plug,Pigtails $30.00 Shipped
-Grey Main Relays $28.00 Shipped Each
Black Main Relays $24.00 Shipped Each
-OBD1 B16 Injectors....set of 4 $60.00 Shipped
-d16y8 wrinkle black valve cover $30.00 Shipped
-D-Series Turbo Kit $430.00
-B16A OBD1 Altinator $60.00 Shipped
Tons of OBD1 &OBD2 D-SERIES ALTINMATORS $45.00 sHIPPED Each
D-SERIES STARTERS $35.00 Shipped Each
Old Jun 7, 2013 | 08:16 AM
Default Re: FS:Civic Parts &Turbo Parts & More
BUMP
Old Jun 8, 2013 | 06:06 AM
bump
Old Jun 10, 2013 | 04:32 PM
Borimoney's Avatar
I can give u. 300 for the turbo kit
Old Jun 11, 2013 | 10:31 AM
88murderedwago's Avatar
What's all with the turbo kit ?
Old Jun 13, 2013 | 11:52 PM
everything but injectors...and some small stuff
Can add Tial 38mm Wastegate in for +$120
I lll take $520 shipped wit tial
or $425.00 shipped with godpseed WG
BUMP
SlaminSohCivic
Aug 13, 2014 10:38 PM
RACEPAK
Feb 1, 2013 09:11 PM
tegman2
Mar 23, 2006 01:15 PM
