dgk's '97 EJ9 build thread
i've been on a bit of a downgrade through the years. not what you normally expect. i started out with an EK9 in 2006, which i sold a year later, as i lost my job. i then bought an EK4 a month after i sold the EK9, as i couldn't bare to be without a honda. had that for a couple of years. i then sold it, as i was meant to be moving back to canada (but didn't). was pissed off big time. my hubby bought me an EJ9 two years ago, as a daily runner. it only cost €750, and came with a brand new clutch and motul gearbox oil :D
so here's just a summary of what's been done to date since i got the car....
23rd july 2011:
- new clutch
- 2nd hand clutch master cylinder
- gearbox oil change
24th july 2011:
- type R gear ****
- type R oil cap
- some stickers
- password JDM & spoon 'socks'
- password JDM rad stay
- mini domo
(all from old civic)
25th july 2011:
- engine oil & filter change
- rear jap plate
30th july 2011:
- 4 x toyo proxies T1-R's fitted
- volk racing gr-n's fitted (i had bought these a few years back, they needed a refurb)
- rays lug nuts put on (from old civic)
- fitted a missing bolt in engine mount (!)
http://www.flickr.com/photos/jbredrebel/6005108345/http://www.flickr.com/photos/jbredrebel/6005108345/ by http://www.flickr.com/people/jbredrebel/, on Flickr
7th august 2011:
new front wipers fitted
17th august 2011:
- fitted USDM pressed plate
- fitted fatlace plate surround
http://www.flickr.com/photos/jbredrebel/6052207581/http://www.flickr.com/photos/jbredrebel/6052207581/ by http://www.flickr.com/people/jbredrebel/, on Flickr
7/8th october 2011
- new n/s wheel bearing fitted
- split pins fitted to front suspension components
6th november 2011
- rear lamps sealed (to fix leak)
9th november 2011
- new air filter fitted
- thermostat
10th november 2011
- fuel filter fitted .. but then old one had to go back in
trailing arm bushes to be replaced // powerflex bought
need cat
16/17th january 2012
rear powerflex trailing arm bushes fitted
18th november 2012
bosch HT leads bought and replaced
24th november 2012
LED bulb bought & installed inside the cabin
30th november 2012
- 2nd hand lowering springs on OE shocks bought (because the car came lower at the back than the front.. WTF)
- 2nd hand cat bought (for NCT)
- shock assemblies replaced on front only
16th december 2012
- oil changed 101XXX miles
17th december 2012
- distributor cap bought & replaced
- rotor arm bought & replaced
- front brake pads bought & replaced
30th april 2013
- new n/s rear wheel bearing fitted
27th may 2013
- oil & filter changed 106XXX miles
6th june 2013
- second hand shocks & springs fitted to rear. springs are cobras, actually. shocks are OE from a 00 EJ9.
- blox LCA's en route from america
- password jdm fender washers also en route
7th june 2013
- bought some touch up paint for the OH's DC5, and my civic.
i know these are only small things, and it's a bit boring. i have been without paid work for a long time, so it takes me forever and a day to get money together for anything. because laws are so retarded here, i don't really plan to do much to the engine. i want to get a D16Z6 intake mani, so i can have a side fed air intake setup. i might put a vtec head on (with loom and ecu).. who knows. want to get a header and an OE VTI cat back exhaust system. i also need to get the wheels painted again.
here's a pic as the car sits now
http://www.flickr.com/photos/jbredrebel/8830858902/http://www.flickr.com/photos/jbredrebel/8830858902/ by http://www.flickr.com/people/jbredrebel/, on Flickr
(tape was cos the stupid council fks put down loose chippings on our road
and recently gave the engine bay a good clean..
hope there'll be more updates to come in the not so distant future
thanks for reading if you got this far!
1997 honda civic EJ9 1.4 tornado (D14A)
http://www.flickr.com/photos/jbredrebel/5973609458/http://www.flickr.com/photos/jbredrebel/5973609458/ by http://www.flickr.com/people/jbredrebel/, on Flickr
purchased 23rd july 2011 / 95ish thousand mileshttp://www.flickr.com/photos/jbredrebel/5973609458/http://www.flickr.com/photos/jbredrebel/5973609458/ by http://www.flickr.com/people/jbredrebel/, on Flickr
23rd july 2011:
- new clutch
24th july 2011:
- type R gear ****
- type R oil cap
- some stickers
- mini domo
25th july 2011:
- rear jap plate
30th july 2011:
7th august 2011:
17th august 2011:
7/8th october 2011
6th november 2011
9th november 2011
- thermostat
10th november 2011
need cat
18th november 2012
24th november 2012
30th november 2012
16th december 2012
17th december 2012
30th april 2013
27th may 2013
6th june 2013
7th june 2013
)and recently gave the engine bay a good clean..
bits arrived in from miami this morning :D
i bought the fender washers to put in place of the headlight bolts & the coolant reservoir bracket bolt.
then i fitted the LCAs
cleaned out my arches. found a bit of rust on the inside of the QP. i scrubbed it with a wire brush to get all loose bits off. it hasn't gone too deep yet anyway. then i brushed a layer of thick grease to protect it for the moment.
i hope to get a brace/arb setup for the rear soon. there's a lot of stuff to get, but i have to focus on one thing at a time. this is a poverty spec build afterall :D
thanks!
one thing that drives me demented about cars in europe, is that we get these lame-*** small engines in everything..
there are A LOT of 1.4 civics here in ireland, and even 1.3's .. like the hybrid civic (06+) are 1.3!
there was an irish domestic EK4 vti with a B16A2.. but they are even rare enough to find. most cars around here are imports. even my own hatch is a UK spec (northern ireland) imported civic.
GrindTimeAuto
Jul 25, 2013 03:23 AM
