Distributor problems d15b vtec w/ obd0 connections what do i do?
Im a noob i just picked up a 90 ef hatch the distributor went out i got an obd 1 ecu not sure what kind cause the label is scatched off..but the distributor has OBD0 plugs but other forums i seen say i should be running an obd1 distributor.
so what distributor should i use that will match the plugs and be right for my engine>?
Timothy Yhtomit
Jan 28, 2019 10:49 AM
