Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Whining sound 2009 Civic SI - what is it?
Old Jun 5, 2013 | 10:42 PM
haxpaxin's Avatar
Default Whining sound 2009 Civic SI - what is it?
DELETE
Old Jun 7, 2013 | 06:57 AM
integra15's Avatar
Default Re: Whining sound 2009 Civic SI - what is it?
Can you hear it in all gears? Does it come and go depending on throttle position? If so might be hearing the transmission gear whine. That is completely normal.
Old Jun 7, 2013 | 08:20 PM
haxpaxin's Avatar
DELETE
Old Jun 17, 2013 | 10:51 PM
rynoleum's Avatar
I have the same issue and its either my idler or tensioner pulley. Sounds like a supercharger whining lol
Old Jun 27, 2013 | 09:04 PM
ek97sedan's Avatar
Yup, this started happening to me a few weeks ago. Hope it's nothing with the tranny rather it be the pulley. They've said it's cheaper and easier to fix
Old Jul 8, 2013 | 01:11 AM
r1cekid's Avatar
you supercharged?
Old Jul 10, 2013 | 09:09 PM
vladd's Avatar
Originally Posted by haxpaxin
Thanks for the reply. I notice it the most in 6th gear, and I hear it occasionally in 2nd gear when the vehicle is decelerating.
Usually the sound in 6th gear is there constantly; however, there are times where just a tiny bit of throttle can enhance the sound when I am in 6th gear.
It's weird that you notice it in 6th gear the most. When my idler pulley went bad on my '08 Si, the whining was heard in every gear. It got noticeable around 5K RPM, and got louder the closer to redline I got.
Old Jul 11, 2013 | 07:08 PM
haxpaxin's Avatar
DELETE
Old Jul 12, 2013 | 09:15 PM
paramnesya's Avatar
Please let us know if Honda is able to (fix or even identify) the whining problem.
My 2010 Civic Coupe LX (approximately 87k miles - yes, I drive a lot) is also making a whining sound. The road noise in my Civic has always been loud, but this is more than just road noise...
I made a recording but it is really difficult to hear.
Old Jul 14, 2013 | 06:35 PM
ek97sedan's Avatar
Old Jul 15, 2013 | 09:36 AM
haxpaxin's Avatar
DELETE
Old May 22, 2014 | 01:59 PM
luder95's Avatar
i dont mean to bring this back from the dead but i just bought an fa5 and that thing whines when i rev it up too, i took the belt off to eliminate any pulley issues and it still made the whine noise, its coming from the passenger side of the engine, anybody found anything out yet? thinking maybe water pump? timing chain tensioner or something in that area
Old May 23, 2014 | 01:45 AM
vladd's Avatar
Which belt did you remove?
Old May 23, 2014 | 07:07 AM
luder95's Avatar
The serpentine belt, the only belt
Old May 26, 2014 | 07:41 AM
haxpaxin's Avatar
DELETE
Old May 26, 2014 | 08:51 AM
luder95's Avatar
That would suck if tranny issues came up, mine is deffinately engine noise I'm thinking at 118000 it's probably time to replace my timing chain, tensioner and guides that's probably my noise
Old May 28, 2014 | 02:56 PM
SpeedOFsmell's Avatar
try changing the transmission fluid to something like Redline. That will be good for it even if it doesn't fix your problem.
kilassapsap
Oct 20, 2014 01:22 PM
honda_boy23
Oct 9, 2011 08:40 AM
kriptonian7
10
Aug 7, 2010 06:59 PM
WILD_WILL
Oct 3, 2006 01:15 PM
1990civicsiguye
Jul 31, 2003 05:01 PM
