B series msd billet distributor 8488 with blaster coil and 6A box
Hey guys how's it goin, I have a msd billet distributor model number 8488. It had never been run on a vehicle only test fit since I'm missing spark plug wires.
This is what msd has to say About it "Finally, a performance distributor for Honda and Acura engines! This all new Pro-Billet Distributor is designed for the popular Honda/Acura ’96-’01 JDM/USDM 1.6/1.8L B-Series DOHC VTEC engine platform. The Pro-Billet Distributor is designed for performance from the insideout starting with a precise billet aluminum housing. Inside this strong new housing is a ball bearing guide for high rpm stability. Hall-effect pick-up assemblies are used to improve trigger signals and are also compatible with the factory The Distributor uses a small external ignition module that creates a much higher energy spark to the . This inductive spark also has longer spark duration and even fires multiple times at lower rpm. This increased spark output improves combustion resulting in improved performance through the entire rpm range."
They want 500 for the distributor alone, I'm asking 500 for the distributor, msd blaster sc coil and msd 6A box. Let me know if you are interested Nd thanks for your time
dyg2001
Feb 24, 2004 09:38 AM
