CROME GOLD TIP-IN setting?
Can anyone please help. The problem I'm having right now is when de-accelerating, my engine dies. How do I change the tip-in on crome gold. I have 440cc RC injector installed.
thanks
thanks
tip-in doesn't control deceleration, your problem is fuel resume (or a physical vacuum issue). try reducing the ignition timing in the decel column below 2500 rpm and add more fuel in the recovery range so it doesn't drop as quickly. Also, go into the idle tab and raise the fuel resume threshold to 2000 (or higher if needed).
norcalB18
Engine Management and Tuning
Dec 3, 2015 08:46 PM
