rattle
Old Jun 5, 2013 | 02:01 PM
armmata's Avatar
Default rattle
i cannot seem to find a rattle or what sounds to be a washer lose only on the right front corner of the car i have replaced the sturts rotors pads sway bar bushings end links and all the bolts are tight have even going back to recheck them. Can anyone help with this
Old Jun 5, 2013 | 08:56 PM
NZXTInerTia's Avatar
Default Re: rattle
Not without more information. You're being very vague on your description. It could be a bolt or a heat shield. Hell even a screw driver that fell into some random spot, etc.
Old Jun 10, 2013 | 12:05 AM
armmata's Avatar
Default Re: rattle
Just put a motor in it all the bolts are tight I have gone through the thing and made sure there tight rattle started after I put strut in so I pulled them and check to see if they were lose but there not
Old Jun 10, 2013 | 12:53 AM
Default Re: rattle
Well, are there any loose panels? Heat shields? Still aren't describing the sound/area too well. Have someone rev the car while you search around.
brent_86
Apr 30, 2007 08:12 PM
madmanmaigret
Mar 24, 2007 07:36 AM
deviant1
Feb 29, 2004 09:16 AM
EF_LSVtec
Nov 15, 2002 10:16 AM
RevedOut
Feb 12, 2002 01:36 PM
