8valve head on 16valve block help
Old Jun 5, 2013 | 01:03 PM
ef9allday's Avatar
Icon3 8valve head on 16valve block help
Need to know if safe for now till I get another y7 head
Do I need to use d15 cam gear or adjustable
Old Jun 5, 2013 | 01:08 PM
ef9allday's Avatar
Default Re: 8valve head on 16valve block help
Motor starts but runs shitty and barely can rev rpms
Old Jun 5, 2013 | 01:20 PM
4drEF's Avatar
Keyboard Humorist
It will work.
Not sure on the cam gear though.
Old Jun 5, 2013 | 01:28 PM
ef9allday's Avatar
I left the 8valve can gear on but y7 belt was way too short so I tried putting my adjustable from my y7 head n it almost fit but still to short ..I got a d15 one n it fits but a little slack thinkiI'm going to try put the 8valvr one back on
Old Jun 5, 2013 | 01:34 PM
24TEN's Avatar
PHANTOM MENACE
This would be similar to my PM3 head on 1.6 block. The belt I used was from the D16A6. The cam gear should still work since it has marks for Si/EX and non Si/EX engines.
Out of curiousity, what ECU are you using? And what is your ignition timing set at?
pogonophobia
16
May 27, 2016 04:18 PM
kartracer4
Jun 27, 2005 05:36 PM
USDM 4G VTEC
18
Jul 7, 2004 05:31 PM
