Moving sale Honda parts everything for cheap
Moving sale need stuff Gone Plz call me only 321 418 2407* Thank you for Looking.
1. B series oil pan B18b1 $25
2. B series stock flywheel $25
3. B series harmonic Balancer no key or bolt $15
4. B series eg/dc top tranny mount $20
5. Crx/ef driver side motor mount $20
6. Obd2 B series alternator $30
7. B series Good passenger side axle $25
8. Obdo 5 speed Da Ls ecu $30
9. Brand new Precision 400cc injectors obd1 plug and play $140
10. Plug and play 275cc obd1 injectors high impedance $20
11. I have 2 D15b7 intake manifolds with fuel rail , throttle body couple sensors good shape both for $10
12. 97 Dc Tail lights in good shape $20
13. D series power steering Pump and Reserve $10
14. Dc and Eg air bags 15$ a piece
15. Map sensors $15 a piece
16. 96-2000 ek ac blower $15
17. D16Y8 Valve cover $15
18. 3 layer metal D series head gasket less then 20 miles , Brand new D series oil pan Gasket for $25
17. DC Gsr window regulator passenger side came of a 2 door 98 integra 20$
18. Y8 cam gear $10
19. D16y8 automatic fuel rail with sensor asking 15$
20. Eg rear shocks like new great condition $30 for both
21.Brand new Never Used Borg Warner T3/T4 T04B Turbocharger I'm Asking $300 Firm If Interested plz call me Only at 321 418 2407
Turbine housing is an O.E. Borg Warner, .96A/R, 'T4' single-scroll 'on-center' design, with a 4-bolt turbine outlet flange
Turbine wheel is 74.2/64.5, 'P' trim (76 trim)
Bearing system is full hydrodynamic.
Thanks for Looking .
18. Y8 cam gear $10
khaledbuiltEF
Jun 14, 2013 12:26 PM
khaledbuiltEF
Apr 21, 2013 02:06 PM
khaledbuiltEF
Apr 11, 2013 04:47 PM
