NJ: FS lotsa stuff, K-series and B-series, LSD, CF hood, headers, ECUs, Pistons, etc.
Old Jun 5, 2013 | 04:39 AM
CHEETAH's Avatar
Default NJ: FS lotsa stuff, K-series and B-series, LSD, CF hood, headers, ECUs, Pistons, etc.
Clutch masters twin disc needs disc $500
Aeromotive fuel regulator new with liquid filled Guage the $sold
05+ PRB A10 engine harness and 06 PND ecu $250
Rsx alternator and starter and charge harness $225
Prb 02-04 ecu $sold
P73 type R, p72 gsr and PCX s2k ecu, and unsure if they work $50 each
B series 82mm turbo pistons used with rings and pins, and $250neg
ID 1000 injectors with pigtails $375 and new dc/eg hybrid racing subharness $sold
Axle back muffler w/stainless steel 2.5" piping for 92-00 civic hatch.. $150
Jrsc supercharger kit used for k20 with extra pulley... $2000
102mm stroker wiseco new all motor pistons and used but good Crower rods.. $650
Swap header I believe Hasport and Rsx kswap header cat flange cutoff, $200 and $250 respectively
96-00 cluster with tach $100
Breather box with 4 - 10an bungs and for use with dual breather filters(not included) $150neg
Obd1 ecu assorted some work some do not, some chipped some not, take them all for $250
92-95 civic carbon fiber hood new but dusty.. $500 local pickup only
Mfactory LSD for k series with carrier bearings... Used $575
Pm box can get full so email is probably better
GBRTuning at a o l dot com
You can also text
917 two seven three .4431
Old Jun 6, 2013 | 01:16 PM
CHEETAH's Avatar
Default Re: NJ: FS lotsa stuff, K-series and B-series, LSD, CF hood, headers, ECUs, Pistons,
sold PRB ecu, fuel regulator and hybrid harness
Old Jun 7, 2013 | 12:37 PM
boostkid345's Avatar
twin disk for k or b
PacsterEg6
May 20, 2010 07:14 PM
Crank
Mar 13, 2009 06:33 AM
kowcain
Northern California (Sales)
10
Feb 1, 2009 12:25 PM
