B20 sleeved,w/ pistons,rods,head gasket!!??
Old Oct 23, 2002 | 08:02 PM
its WANG yoO's Avatar
Default B20 sleeved,w/ pistons,rods,head gasket!!??
ok i was looking at a B20 from http://www.hmotorsonline.com
i am wondering if it will hold up if i sleeve the block to 84mm and get some good pistons/rods....and head gasket...with head work good tuning,770cc injectors...i'm planning to run 20-25lbs of boost!
will i have any problems with **** breaking???
thanks guys!
Old Oct 23, 2002 | 08:19 PM
bottlefedb18c1's Avatar
Default Re: B20 sleeved,w/ pistons,rods,head gasket!!?? (hybridRhatch)
that is what i am trying to find out or if i should just sleeve a b18c1 block to a 2L? or even stay the stock dis. with the b18c1 and have it sleeved
Old Oct 23, 2002 | 09:25 PM
Mr. Softee's Avatar
Default Re: B20 sleeved,w/ pistons,rods,head gasket!!?? (turbogsrb18c1)
its probably a better idea to sleeve the gsr block. oil squirters and a block girdle make life easier. a sleeved b20 is in no way bad at all though, its the same thing as a sleeved b18b or a.
Old Oct 23, 2002 | 09:35 PM
Default Re: B20 sleeved,w/ pistons,rods,head gasket!!?? (94goldjungsr)
i am leaning more with the sleeved b18c1 block myself for that reason
Old Oct 23, 2002 | 10:31 PM
turbopanda's Avatar
why do I feel like i've made the wrong decision?
how much would it cost to have my B18C2 block sleeved by GE or Darton? Just out of curiosity..
Old Oct 23, 2002 | 10:35 PM
Flamenco-T's Avatar
Default Re: B20 sleeved,w/ pistons,rods,head gasket!!?? (turbopanda)
sleeving is arround 700ish plus about 100 is machine work ( bore and hone )
get a GS-R block, and sleeve it to 84mm....
Old Oct 24, 2002 | 01:56 AM
inspyral's Avatar
Default Re: B20 sleeved,w/ pistons,rods,head gasket!!?? (Flamenco-NA)
GSR block with LS/B20 crank and rods sounds like a good setup...
Old Oct 24, 2002 | 05:38 AM
Default Re: B20 sleeved,w/ pistons,rods,head gasket!!?? (inspyral)
that will take forever to find around here....what about just finding a B18B complete engine and getting that sleeved....same thing though right?
Angel4768
Nov 21, 2011 08:21 PM
7rrivera7
11
Jul 29, 2006 09:51 PM
SpyderZEX
Dec 4, 2003 04:27 PM
bsemeyn
Sep 30, 2003 06:15 AM
