Mystery part? *pic*
11, 12, and 14 looks like its the suspension bulkhead if i'm not mistaken.
32 is the Firewall
18 looks, when compared to the physical photo, to be the framing just below the suspension bulkhead, which would make #1 something attached there.
So maybe yeah, torque mounts or some kind of axle system mount.
I'll see if I can see something like this in my bay at lunch if this isn't solved in a few hours
32 is the Firewall
Now that I recall correctly, that's almost certainly what it is.
"Outrigging" on a big-rig or large utility truck is the term for a jacking point or a stabilizer when using a boom, so a jack point is almost certainly what that is
Op- look closely @ your 1st green paint pic. Now look where the subframe for the steering/suspension bolts to body. The green/black pic is the almost the perfect angle as the diagram. These are sections 1&5, I'm certain of it. What would be the subframe "rails" (if you will) start here @ the bottom of the firewall. Yep, jackstands also go on outer section of this piece.
crx_975
17
May 8, 2012 06:55 PM
lorusblue
Classic Hondas
13
Sep 26, 2011 03:38 PM
Budget EJ
17
May 1, 2007 11:48 PM
DC2-JRSC'd
Nov 5, 2004 07:30 PM
