Wiring help with Prelude fogs in EF Si
I just snagged some Prelude fogs from a yard, I have them wired up, and followed a walk through that had the wire colors mixed up and that was a nightmare in itself. After finally figuring out what was actually what I am not having any luck figuring out how to wire in the relay.
I'm using the Mitsuba rc 2201 and cannot figure out what I'm missing. I have tested the relay, it works, I'm just a retard when it comes to wiring.
The lights work fine when I don't have the relay wired in, so I got irritated and just left it. Of course this burned out the switch (I was using the one from the prelude, not expensive real ef one yet
).Basically all I need is someone to tell me what the 1,2,3,5 pin labels stand for. Or if there is an install for dummies write up that works too.
Lastly, is there a more common oem switch that I can use instead of the actual fog light switch that is worth more than gold on ebay? I have a rear defroster switch on hand. Thanks a ton!
Thanks, I had already seen that one though. I know the relays are good, I've swapped them with other working ones. What I need to know is how it gets wired into the fog lights harness. What goes to and from the pins?
Ok - sorry. I thought you just needed to see how the relay was wired.
Here is how to do it with a Bosch relay
Bosch -> Mitsuba
85 -> B
86 -> D
87 -> A
30 -> C
Bosch -> Mitsuba
85 -> B
86 -> D
87 -> A
30 -> C
Awesome man, that helps a ton. Hopefully last question from the short bus, my Mitsuba relay says 1,2,3,5 not abcd or am I just missing something?
In the link I sent, it shows actually relay pins and assigns them letters.
To verify that these pins/letters are correct, hook pins 'B' and 'D' to power and ground.
It doesn't matter which one goes where - you should hear a click.
If you get a click then all is good.
