Adding power to a D15B7
Old Jun 3, 2013 | 10:40 AM
RoryMcMahon's Avatar
Default Adding power to a D15B7
I'm dropping in a new engine, and my Dad is insists on getting another B7 to keep the swap as simple as possible. I want more power if were spending the money on a new engine anyways, but considering he's financing the project, I might have to go with a B7.
Are there very many cheap, easy options to increase the power of that engine down the road? I'll admit I don't know much about performance parts. What about exhaust headers? Or a different intake? Or a turbo?
Would any of these bring the engine to a comparable level of a Z6 or ZC DOHC?
Thanks
Old Jun 3, 2013 | 10:45 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Adding power to a D15B7
Put a Z6 head on it with proper ECU.
Old Jun 3, 2013 | 11:12 AM
Joshka89's Avatar
grumblemarc's 3rd link in his sig will tell you what you need to know.
Along with countless other "how i go faster" posts
Old Jun 3, 2013 | 11:22 AM
The Grumpiest
I don't know how the OP thinks a turbocharged engine is by any means "cheap".
The 4th link is excellent as well.
Old Jun 3, 2013 | 11:29 AM
S2BumpsticksGSR's Avatar
A lot of people assume(not just Honda owners) a turbo kit is a bolt on don't worry about it affair. Couldn't be further from the truth- good luck op. I suggest a head swap, too, when Dad's not looking.
Old Jun 3, 2013 | 11:36 AM
Joshka89's Avatar
You also haven't told us your car model.
It could very well be that you could drop in a a GSR or B motor which is cheaper than boost (and easier in my opinion).
If you HAVE to use a D15B7, which isn't great, and want more power, then you're gonna have to spend some serious cash on some well tuned parts, or forced induction. All of which costs more than just buying a more powerful engine.
Old Jun 3, 2013 | 11:39 AM
Joshka89's Avatar
And just to expand on this, just a cursory list of what it takes to boost:
Snail, intake, headers, exhaust, ecu, injectors, fuel pump, cams, intercooler, cutting, welding, money.
The closest things there are to "bolt on power" would be short rams, which is really only applicable to muscle cars IMO, a cold air intake, which wont' give you much without other tuning anyway, or a supercharger if you didn't have a honda.
Old Jun 3, 2013 | 12:34 PM
sleepyaccord96's Avatar
i dont think a d15b7 is even worth buying as a replacement... just buy a d16z6 or d16y8 and throw it in there and dad will never know the difference... and then later on post on here and we can help you wire in vtec... d15b7 is a waste of time...
I have 2 d16y7 complete swaps that are hard to sell because they are so slow and so shitty in general
Old Jun 3, 2013 | 12:36 PM
jbpnoman's Avatar
Are you high? 8 of the 10 things you listed are completely unnecessary for boost (congratulation on realizing you need a turbo and intercooler for boost, though), and superchargers do in fact exist for Honda motors.
OP, swap in a Z6. You can get one for the same cost as a B7, will bolt straight to all of your B7 periperals, it will give you VTEC, an extra .1L of displacement, and a MUCH more resilient motor to work with should do use any real power adders down the road.
Old Jun 3, 2013 | 12:49 PM
Joshka89's Avatar
I wouldn't say completely unnecessary, sure you could do a low psi boost and not need all that. But it still isn't cheap is my point. I wouldn't run boost without a better fuel pump and injectors. Not to mention if you run stock exhaust it really won't cut it.
So yeah, i was way way off I suppose.
Old Jun 3, 2013 | 12:55 PM
jbpnoman's Avatar
It can be done on the budget side, if you shop around. My entire setup cost a few cents under $1500 on a Y7, and doubled it's BHP to the wheels. I guess it all depends on your definition of cheap. A complete LS swap would cost about the same, and net 60-70 less WHP.
It's all good though
Old Jun 3, 2013 | 01:06 PM
JuggerNaut-CTR's Avatar
Happyfeat2006
Feb 11, 2008 07:16 PM
compprat
Apr 13, 2006 12:05 PM
snoochtodanooch
Aug 31, 2005 06:21 AM
CivicHB89
13
Dec 16, 2004 01:44 PM
Blue CRX
11
Aug 12, 2004 07:22 AM
