1989 Dual point fuel injection (DPFI) fault
Old Jun 3, 2013 | 10:29 AM
DCcrx's Avatar
Default 1989 Dual point fuel injection (DPFI) fault
looked at my CPU and have 16 flashes. Fuel injector. how do i know which of the two are bad? can i remove them and clean them or rebuild them? where the best place to get these? thx
Old Jun 3, 2013 | 09:07 PM
skill178's Avatar
Default Re: 1989 Dual point fuel injection (DPFI) fault
Unhook the plug wires and turn it over, should get gas on 2 pistons (remove plug and see if they are wet) if one is bad. Best route IMO, buy a mpfi intake and swap it.
Old Jun 3, 2013 | 09:16 PM
jonGSR's Avatar
You may also want to check your main fuel relay. That could also be the cause as well.
Old Jun 3, 2013 | 09:58 PM
dopesk8er87's Avatar
When I had a code 16 it turned out to be my main relay. Easy fix, and honestly a must for these cars.
Old Jun 4, 2013 | 08:23 AM
DCcrx's Avatar
the car starts and runs good. I get a light miss when idling. I checked the CPU out of curiosity and saw the 16 flashes . should I be concerned? how do I reset the CPU? thx.
raymondpowens
Apr 19, 2015 11:14 AM
Baserloks
Jun 2, 2009 10:57 AM
CasperX
Aug 25, 2008 03:29 PM
2ndGenREX
Jan 12, 2007 01:43 PM
Desert_Rex
Jan 22, 2005 01:44 AM
