Is a B18B motor for $900 a good deal?
Old Jun 2, 2013 | 08:24 PM
Project-89Honda's Avatar
Default Is a B18B motor for $900 a good deal?
found a B18b for $900 is it a good deal
found a b18c with lsd tranny for $3800...is that a good deall
bothe come with warrantee
will they bolt up too a 89 crx???....
found a website thats a pretty good engine and tranny place just dont know if price is right or wrong ...endly motor and trannys to chose from .........
what too get
Old Jun 2, 2013 | 08:33 PM
b20VAngel's Avatar
Default Re: Is a B18B motor for $900 a good deal?
the tranny is over priced i think motor is ok but for a few more hundred you can get a vtec b series and theyll bolt up with the right mounts and youll need a cable to hydro conversion on that tranny.
Old Jun 2, 2013 | 08:59 PM
original mounts wont work? n i plan on v tec for whatever i buy just dont know whats good n bad yet
Old Jun 2, 2013 | 10:33 PM
EFlovin''s Avatar
No, a Crx comes with D series mounts. You need b series mounts,axles, shift linkage, etc. Also the B18B is NOT vtec. You would need to go LS/vtec(b18b block with a b16a,b16a2, b18c1,b18c5, or B18C head. That itself is a hassle, and most people can't build a proper LS/vtec and forget the small things, so they blow the motor.
Old Jun 2, 2013 | 10:40 PM
no cutin or welding right ??? can it all just be bolted on?
Old Jun 2, 2013 | 10:48 PM
EFlovin''s Avatar
You are going to have to "move" for lack of better words the front tranny mount. But that's it. Not hard, just get a sledge hammer and bang it out of the way or cut it off. It's simple. You will also need the proper wiring harness and ECU
Old Jun 3, 2013 | 10:53 AM
F22Master's Avatar
What?? No, you dont. That's for F, H, or K series. B series will bolt right in with the correct aftermarket mounts, which cost anywhere from $90-$350.
Old Jun 3, 2013 | 01:02 PM
EFlovin''s Avatar
I had to move mine. I can post a picture if needed. I used no name mounts though...I also forgot he might have to make room for the alternator and do a little banging(which I had to do too)
Old Jun 3, 2013 | 05:58 PM
jimmy o.'s Avatar
Both are overpriced imo but them again I'm cheap and kinda old school
Lil_Wyte
Feb 4, 2010 05:37 PM
foxxor
Jul 11, 2007 12:46 PM
stemiched
12
May 14, 2007 09:00 AM
kixcrx
Jan 15, 2007 08:43 PM
delsol93guy
Jul 11, 2005 04:49 AM
