93 Accord LX Electrical Problems
Old Jun 2, 2013 | 04:03 PM
unowire's Avatar
Icon2 93 Accord LX Electrical Problems
Bought my daughter a 93 Accord LX with only 120K on it. Shortly after the purchase the rubber section of the hydraulic clutch line started leaking. I replaced it & my daughter pumped the clutch pedal as I bleed the system. On our test drive I noticed the following conditions:
Speedometer inop, Tach inop, basically all functions of the instrument cluster inop except the lighting.
None of the power windows work, the clock doesn't work, & the wipers work in slow & fast but not in intermittent.
I thought she might have pulled something loose as she manipulated the clutch pedal, but have found nothing.
All fuses check good. All other electrical items work fine.
Any help would be appreciated.
Old Jun 2, 2013 | 11:10 PM
holmesnmanny's Avatar
Default Re: 93 Accord LX Electrical Problems
It's not clear if those items worked before you fixed the clutch hose.
Old Jun 3, 2013 | 01:30 AM
unowire's Avatar
This is a very clean, low mileage car, every feature on this car worked prior to the replacement of the clutch hose.
Old Jun 3, 2013 | 01:38 AM
I would take off the lower dash cover and look around. Perhaps she pulled apart a connector for the cluster. Is the car running fine otherwise ? If the speed sensor and icm were actually bad your car would be running bad so i'm inclinded to think something got pulled apart that goes to the cluster. Just a guess tho.
Old Jun 3, 2013 | 01:43 AM
Also did you check the fuses under the dash ? The window relays should be in the engine but i think the others there might be under the dash.
jrun666
Apr 18, 2011 07:23 PM
mrfootball420
Dec 7, 2010 05:12 PM
Nixon161
Oct 31, 2007 11:07 PM
blue_eyed_taoist
Jan 3, 2006 08:46 AM
