NJ NJ FS 1999 EBP EM1 CLEAN TITLE
Time has come to move on from this car. Its going to hurt to see it go but I can't afford this hobby at the moment and need to move on for now. This car is extremely fun to drive and the motor is "bullet proof" according to my friends. however it needs a really good tune since I have got around to having it dyno tuned. (it runs rich ) other then that the car has no real issues and was really well put together, didnt cut any corners and everything is practically brand new on the car suspension and motor wise, except the spoon caliper which i purchased used off a member on here. if anyone has any other questions about the car please email or TEXT only 551 655 3423
sabamichael@gmail.com
Asking price is 8000 obo, dont want any trades unless its a BMW in the same price range. the car is worth more money and i would ask for more but THE BELL HOUSING JUST BROKE ON THE CAR SO SELLING IT AS IS FOR THIS PRICE. IF I FIX THE HOUSING THE PRICE WILL GO UP A LOT MORE. car has over 4500 in suspension parts alone. and the motor build wasnt cheap either.
If someone wants to offer me a BMW in good condition and good mileage I can consider adding money on top other then that dont offer me trades.
Exterior
OEMhead lights
Si OEM lip
Stock mirrors
OEM EM1 rear mud guards
will include OEM EM1 front mud guards they are broken tho
Interior
Spoon Sports 2nd gen Steering Wheel
Spoon Sports EK Hub
Spoon Sports 5 speed shift ****
S2k push to start
Water temp gauge
Oil Pressure gauge
Sony Radio, 2 10" kicker subs
B&M short Shifter
DC2 Red Stitch Shift Boot
Stock EM1 front and Rear seats
OEM front floor mats
Spoon sports Reservoir socks
Suspension
USDM ITR 5 LUG CONVERSION
JDM ITR 16" RIMS
DUNLOP DZ101 205-45/16 TIRES ALL AROUND
Pic Select P3 coilovers 12k front 10k rear
Spoon Sports Twinblock Calipers
Spoon Sports Blue lug nuts (missing 2)
Brembo Blank Rotors F&R
Duralast Gold brakes
HardRace Front & Rear Camber kits
HardRace Roll Center Adjusters
HardRace rear trailing Arm bushings
HardRace front lower control arm bushings
Function7 Subframe reinforcement Bar
Function7 lower control arms
HardRace front sway bar end-links(not installed)
HardRace Tie Rods
Cusco Front & Rear strut bars
Motor
B18C- Block
ITR oem pistons
ITR oem rods
Arp rod bolts
kings performance bearings
itr oil pump
itr water pump
itr timing belt
Arp head studs
P72- GSR head
Supertech Dual Springs
Supertech Ti retainers
Stock oem valves
Rocket Motorsports m22x cams
Skunk2 Adjustable Cam Gears
Skunk2 Pro Series Intake Mani
Skunk2 68mm Throttle Body
Rc 310cc injectors
Aem High Flow Fuel rail
Aeromotive Fpr
Checkred Fuel pressure gauge
Fuel line tuck kit
Rywire clutch line tuck
Stock Header
ECU
Hondata s300
HOW IT COULD LOOK WITH SOME ENKEI'S 92'S
PICTURE OF THE PIC'S AND THE HARDRACE REAR CAMBER KIT
SHITTY PICTURE OF THE ENGINE BAY WHILE I WAS DOING THE FUEL LINE TUCK
I know I'm missing things from the car. but you can just ask and ill answer any questions. with a tune the car should be around the 200-215 whp range.
Exterior
OEMhead lights
Si OEM lip
Stock mirrors
Interior
Spoon Sports EK Hub
S2k push to start
Water temp gauge
Oil Pressure gauge
B&M short Shifter
Suspension
JDM ITR 16" RIMS
HardRace Tie Rods
Motor
B18C- Block
ITR oem pistons
ITR oem rods
Arp rod bolts
itr oil pump
itr water pump
itr timing belt
Arp head studs
P72- GSR head
Stock oem valves
Rc 310cc injectors
Aeromotive Fpr
Fuel line tuck kit
Stock Header
ECU
Hondata s300
make your offer...the only thing is that if i fix the trans the price will go up slightly..this car is worth more considering the parts but i know ill never get all my money back but not trying to lose out either...i can fix the trans for the right price.
darkdemoneg
Nov 22, 2009 02:00 AM
gene.
Jun 8, 2009 09:53 PM
Chicago_Type_R
May 4, 2008 09:02 PM
