Help with my 1998 Honda Accord?
Old Jun 2, 2013 | 12:14 PM
ThumperDumper's Avatar
Icon2 Help with my 1998 Honda Accord?
Hey, Recently On the way back from work it started to thunderstorm real bad and i might have driven through some puddles. I also have short ram intake and the car is very low, its a 1998 honda accord with a h22 swap in it. Its only 80xxx on the engine. For my car there is a way to turn on that you have to hit the pedals in a certain order for you to turn the car on and everytime you push the pedal down the check engine light pops up for a second to show you pushed the pedal. but on the way back while I was driving All the lights on the dash popped up(e brake, check engine, abs, etc) for a couple of seconds then they turned off. After that at every light When i idled I was going from 300Rpm-1000rpm( Im usually around 900rpm). The next day I Find out that after driving my car I cant turn the car on for about 10 minutes or so, What do you think the problem would be? any help please now its still driveable. Once I drive it and try to turn it back on the check engine light and battery light pop up but you hear it try to turn on. You wait 10 minutes the check engine light goes away and it turns on, what do you think the problem is I think it may be a computer problem. I do not have a scanner so I cannot scan for the codes
esanchez
Mar 10, 2011 05:24 PM
speedracer28
Jul 14, 2010 10:38 PM
