Rattle/clunking from front end replaced and checked stuff still no luck
Old Jun 2, 2013 | 12:05 PM
dannyb18c's Avatar
Default Rattle/clunking from front end replaced and checked stuff still no luck
I have. 95 civic coupe dx. Has manual steering. I have just replaced innner and outer tie rods, upper and lower ball joints, both cv axles, both front wheel bearings, two new front tires and it all aligned. Still making a rattle or clunk somewhere. The rack bushings look ok. It's pissing me off really bad!!
Old Jun 2, 2013 | 12:12 PM
TypeRfit's Avatar
RESIDENT
Default Re: Rattle/clunking from front end replaced and checked stuff still no luck
Check your sway bar endlinks. They are pretty cheap and easy to replace, I had the same problem on my Teg and that was what was wrong.
Old Jun 2, 2013 | 12:13 PM
Wdpfreak145's Avatar
Check the struts? Does it happen when you hit a bump or when you turn the wheel or what? We need more specifics.
I had to replace my lower control arm bushings after they got old and dry rotted, so I opted for the HardRace bushings. The old ones made very loud clunking/banging sounds when turning the wheel either way.
Old Jun 2, 2013 | 01:43 PM
dannyb18c's Avatar
It doesn't even have a sway bar lol. It happens going over any bump at all no matter how minor. The control arm bushings are old but not gone.
Old Jun 2, 2013 | 04:11 PM
Then perhaps you just have a blown strut.
William1991b
Oct 18, 2017 09:57 PM
SonicC
May 16, 2017 07:03 AM
muddywj
Feb 1, 2015 12:43 PM
Brainfreeze
Transmission & Drivetrain
Sep 5, 2014 09:17 PM
dmg2006
Jan 2, 2006 07:48 PM
