05 CRV Headlights Keep going out
Hey guys,
I did a quick search on here to see if there was a trend and did not find anything. As the title says, I am having a problem with my low beams. I bought the CRV in October from Carmax and since then about every two months the low beams have to be replaced. They usually go out within a couple of hours of use of each other too. I have a warranty with Carmax but my deductible is 250 so I want to see if it's maybe a bad fuse or something that could be causing this? Any help would be appreciated. Thanks in advance.
Brian
Brian
Bump. Anyone have ideas where to start? Checked fuses yesterday. Looked good and used a multimeter to check continuity. That was my only guess.
When you replace the bulbs, are you touching them with your bare hands? If the glass gets contaminated, they'll burn out super quick. Also, I'd check the voltage with the multimeter along with amps... Might be too much.
Jdmintegr
Honda CR-V & Element
Mar 11, 2016 06:25 AM
be4unvme
22
Jul 2, 2012 10:52 AM
granturismonut2
Sep 9, 2006 07:55 AM
