8200 RPM
I have a built up b16a dohc vtec from japan in a 95 hatch. Forged pistons rods, cams, injectors, big fuel pump, headers, intake. The hatch has an rpm gauge with the red line at 7000 rpms. The original motor was a sohc non vtec. I was told at the local meet that the motor I have actually does not red line until 8200 rpm. Does any one know how high I can safely rev my motor
First gen B16A redlines at 8200. Second gen B16A redlines at 8500 MT, 8200 AT.
Have your car professionally tuned, and let your tuner decide how high your motor can rev.
If you loved me, you'd all sell me your magic cards to me today
118 mph is 190 kmh. I will ask my mechanic if he tuned it. You would think if he put in a big pump and injectors, skunk 2 cams he would do a tune.
So my buddy said that I should be able to redline allittle higher than 8500 because I have forged pistons, rods and darton sleeves. Is that true?
It has an upgraded valve train. We put a new head on it when we rebuilt the bottom end. So I talked to my mechanic. It's the stock ecu. He said that he "flashed" it when he did the cams and injectors.
so you dont know what's in your motor?
very very VERY simple solution, have the car tuned by a pro and set the limit just after peak power, people always want high revs but they don't realize all they are doing is going slower and hurting their motor.
if you are doing more mods and then getting it tuned keep the car under, say 5k until then just to be safe.
once you do ANY mod to the engine valvetrain or any internals the stock tune, and with that, rev limit goes out the window.
if you make 150hp at 5000 and 140hp at 6000 why rev past 5? your only losing power even if the motor can handle it
It's more complex than just "where do you stop making power". In a perfect world, you would redline just before peak mean power through the shifted power band hits a negative delta, and fuel/ignition cut just after that. I'm not going to go into the math explaining why that's true - feel free to learn calculus, or trust me on it.
