no start after 10 minutes
Old Jun 1, 2013 | 05:33 PM
votex5's Avatar
Default no start after 10 minutes
My 1990 civic stalls after 10 minutes and then wont start for a couple of hours. Have replaced main relay and wires, plugs, ignition coil, but same
problem persists. I hear the three clicks have fuel but no spark. Any ideas
Old Jun 2, 2013 | 11:45 PM
holmesnmanny's Avatar
Default Re: no start after 10 minutes
Get a junkyard distributor and see if that fixes it.
Old Jun 4, 2013 | 07:21 PM
SI-Freak's Avatar
I had a similar problem on my 2000 Honda Civic SI, it turned out to be the main coil that was not giving a good enough spark to the plugs. I would recommend checking the distributor cap and rotor for oil, cracks, or a short ignition from the rotor.
Did you take out each spark plug and checked for the correct color of spark if any?
Old Jun 12, 2013 | 04:34 PM
votex5's Avatar
Will follow up and check spark and look to check the rotor and cap, thanks
Old Jun 12, 2013 | 04:38 PM
grumblemarc's Avatar
The Grumpiest
Spark should be bluish white.
Old Jun 13, 2013 | 11:51 AM
SolScifen's Avatar
Get your icm tested. They can fail with heat.
Rahes
Nov 29, 2011 08:22 AM
ex_ricer
Aug 14, 2008 02:14 PM
dnoredsi
Feb 7, 2005 08:48 PM
widecoupe
May 12, 2002 11:26 AM
96whitels
Aug 19, 2001 02:06 AM
