90 EF Sedan Coolant Leak
Help!! I am smelling a coolant on my 90 Civic EF sedan like if it were leaking but I can not find were it is leaking. It seems to be coming from were the intake manifold is but when I check my hoses they all seem to be fine... When I get under my car I notice that there are water marks all over my cat converter.... Any advise on what i should check???
Maybe the orings on the pipe that connects water pump to thermostat housing or there's some hoses that go to or from intake. Did u use a new intake gasket and a good head gasket?
Does it leak when you run the engine at idle?
If so, try wrapping the hoses with paper towel.
Start the engine for a little while and the paper towel will get wet where there are leaks.
Good way to find pin-holes.
jdmboy96
18
Sep 3, 2009 08:51 PM
