transmission options
Old Jun 1, 2013 | 07:57 AM
ChokolAwt's Avatar
Default transmission options
Hey,
So my 5-speed transmission crapped out on my 97 lx last night. Which transmissions could I look for? just 94-97? will h22 manual transmissions fit? I just want to know what other options i have to broaden my search.
thanks
~Tim
Old Jun 1, 2013 | 08:09 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: transmission options
90-97 Accords. 92-96 Preludes, any F22/H22 trans should fit. Not sure on F23/H23 MT transmissions.
Differences are gear ratios between CB/CD and the BB's.
Old Jun 1, 2013 | 10:22 AM
ChokolAwt's Avatar
thanks!
I was doing some research on exedy.com
90-97 f22 clutch - 225mm - 24 spline count
92-01 h22/h23 clutch - 219mm - 24 spline count
so it looks like as long as i keep my f22 clutch and pressure plate, i could use any of those transmissions? Do you have any insight into axles/halfshafts? I read earlier that all F/H starters are interchangeable. I'm also assuming I will just be reusing my f22 tranmission mounts if i do opt for an H-series trans.
Old Jun 1, 2013 | 11:14 AM
MAD_MIKE's Avatar
MM Gruppe B
AFAIK, those years of transmissions use the same or similar case.
Just use the axles that are for your car. Accord axles for an Accord, Prelude axles for a Prelude.
There are AT and MT starters, othewise they probably are. But I dunno if a F18 starter is rated the same kW as a H22A redtop starter.
Yup. Only mount change with F22 vs H22 is at the front of the engine due to SOHC vs DOHC.
Old Jun 2, 2013 | 02:24 PM
ChokolAwt's Avatar
awesome. thanks for the info mike!
Old Jun 2, 2013 | 02:31 PM
Mishako129's Avatar
That stinks. So what is it that causes a 5 speed transmission to give out?
I am going to swap a 5 speed transmission that came from a car which had about 200,000 miles on it (an H23 trans). I hope its in good condition still.
Someone said to use GM Sychromesh or something.
black06lude
Oct 27, 2006 12:03 PM
machine4321
Jan 31, 2005 06:49 AM
92hondalude
Dec 12, 2004 05:12 PM
2.2L EH2
Oct 2, 2003 03:11 PM
